Ford Reinvents The Slushie - Or Not.
Re: Ford Reinvents The Slushie - Or Not.
That's not a new idea, that's obsolete technology. Watch videos of people shifting with two sticks...
http://www.youtube.com/results?search_query=twin+stick
It's not parallel transmissions, though, it's serial. For parallel transmissions like a DCT you'd need two clutch pedals...and you'd have to heel-toe them, or get a hand throttle.
Post by Squint »
Yeah, I had assumed it had existed before, just didn't actually do any research. <-- Lazy. :D
DKaz
Cars: Mazda3, Matrix, R3
Post by DKaz »
I saw that recently, pretty neat, kinda like altering the final drive?
09 Mazda 5 GS 6MT - His
12 Mazda 3 GS-L Skyactiv 6MT - Hers
They needed to put in an idler gear to reverse the rotational direction and instead of being just an extra cost to them, Mitsubishi turned it into a marketing asset by adding a 2nd ratio to choose from. It wasn't like low range on a SUV transfer case - not that much of a difference in ratio between the two choices, but an appreciated choice toward optimizing for performance or economy. Effectively, there were really only 7 distinct ratios, not 8, since two of the choices virtually overlapped.
Chris H.
Post by Chris H. »
Rope-Pusher wrote:Image
Hmm...if you were in Economy mode, and you were going to downshift to pass someone, would you downshift to 3rd and then select Power mode? :?
I imagine it's not a shift-on-the-fly transfer case...prolly have to be stopped or under 20mph or something.
paul34 wrote:You probably wouldn't be passing anyone on a Colt.
Too young to be ridden!
