Fast shifting
1320 feet of adrenaline
manualshift
Cars: 2010 Mazda 3 Sport GS
Fast shifting
Postby manualshift » Thu Jun 11, 2009 8:41 pm
Is fast shifting necessary when drag racing, and i mean something like
http://www.youtube.com/watch?v=L-99Ghk3 ... re=related
Re: Fast shifting
Postby Rope-Pusher » Thu Jun 11, 2009 11:38 pm
^ Yes, if you are serious about it, since every shift is an interruption in the time you have to apply power, sew ewed knead too shipht fassed two redoose the interruption time.
Leedeth
Re: Fast shifting
Postby Leedeth » Fri Jun 12, 2009 1:45 am
You only need to shift as fast as how fast the RPM falls to the target RPM in the next gear.
Like, if your target RPM is 5000, then you need to be ready to clutch out slightly before that.
Wait.
You can get extra power by shifting fast and using the momentum of the engine, while dragging the RPMs down, to further boost the car's speed.
So I guess you need to shift as fast as possible.
mad_finn
Re: Fast shifting
Postby mad_finn » Fri Jun 12, 2009 2:05 am
And in low power wehicles, wich dosen't have enough power to cause wheelspin, you can keep full throttle while you are shifting.
it will cause similiar effect to this
Leedeth wrote:You can get extra power by shifting fast and using the momentum of the engine, while dragging the RPMs down, to further boost the car's speed.
only bit stronger, and RMP's dont fall aslow like thy would here, but causes greater risk to brake your differential, gearbox, and engine.
Re: Fast shifting
Postby theholycow » Fri Jun 12, 2009 8:47 am
I imagine that fast everything is necessary in drag racing.
Return to “Drag Racing”
