upshift
1320 feet of adrenaline
newbie
upshift
Postby newbie » Fri Jul 02, 2004 2:25 am
i have to enquiries
1. wat is the best way to upshift...is it ok to upshift while still accelerating...ie. accelerate hard than clutch in while still accelerating than complete the shift....
2. wat is double clutch to upshift
ReckLess
re:
Postby ReckLess » Fri Jul 02, 2004 4:28 am
man i am so confused with you questions... but i'll try my best...
double clutch is pressing the clutch twice to shift.... example...
double clutch downshifting:
assume your in third gear
1. press clutch
2. put the transmission on neutral
3. relase the clutch
4. clutch again
5. second gear
about your upshifting question... it's kinda confusing but don't despair look at the faq portion or the video... i think there is a previous topic about upshifting you can look that up too...[/i]
:twisted:
Postby IMBoring25 » Fri Jul 02, 2004 11:56 am
I think what you're asking about on #1 is never lifting the gas. I believe that's usually called a power shift. There are those who do it, but it's very hard on the car. What should be done is to let off the gas to the point where the engine is neither speeding you up nor slowing you down, clutch in, shift, and clutch out while using an appropriate amount of gas to match the RPM's the engine will be turning.
Usually, in a car with a synchronized transmission, double-clutching to upshift will not be necessary.
newbie
Postby newbie » Mon Jul 05, 2004 9:51 pm
i thought when you double clutch you have to rev match it when you have it in neutral
Postby IMBoring25 » Mon Jul 05, 2004 10:11 pm
Yes, but usually that is not necessary for an upshift.
coolguy
Postby coolguy » Fri Jul 23, 2004 3:04 am
Right. But if u insist u can do it in upshifting as well :roll:.
ReckLess
re:
Postby ReckLess » Fri Jul 23, 2004 8:04 pm
does it have the same effect as downshifting? i mean does it help the syncros' loads off?
:twisted:
coolguy
Postby coolguy » Fri Jul 23, 2004 9:03 pm
Good question, but I would guess not...............otherwise a lot of manual drivers would have had said something about this.................I personally don't do it :lol:.
ReckLess
re:
Postby ReckLess » Fri Jul 23, 2004 9:12 pm
yhea most of the driver in the world does not know how to or what is double clutch or even heel-toe
:twisted:
Return to “Drag Racing”
