Klasse All-In-One and Sealant Glaze
Standardshifter
Site Admin
Cars: 2005 Legacy GT, Buell
Post by Standardshifter »
Twice a year, I use the two products on the right on the Subaru:
Klasse All-In-One (AIO), is a one step cleaner protector, polish, and long lasting acrylic protection. I use it after washing and claying the car. Helps remove the last layer of paint contamination stuck to the paint. Just need a tiny amount, ie size of a nickel for each body panel of the car. Should just see a bit of haze behind the damp towel or pad of choice before it disappears. You then wipe it off immediately.
I usually then throw a layer or two of Klasse Sealant Glaze, which is just a protective acrylic coat. Can be a bit stubborn to get off if you try to remove it too soon (tacky) or too late (hard as a rock). Found if you apply it to a couple of body panels and then remove it, the timing is about right.
Takes a while, but the protection lasts multiple months, much longer than even synthetic waxes.
-Standardshifter
