RomPirate's new-new-new-new car
RomPirate
Post by RomPirate »
Well, new to me at least.
I've been looking at getting another car for some time now. Took a look at the Fiesta ST, the FR-S and some E46's. I'm a shade tree mechanic that happens to like tools a lot too, and my other cars have been so darn reliable I haven't had a good wrenching in some time. It only makes sense that I buy one of the least reliable- I mean highest maintenance cars in modern times.
She doesn't run at the moment. Aside from the bumper damage the rest of the car is complete. But dirty. Very dirty.
97 Prelude 5spd swap FTW! (Sold! :( )
07 Mazda MX-5 Sport (DEAD)
07 VW Rabbit
04 Mazdaspeed Miata (Sold!)
05 RX8 (Sold!)
95 Wrangler
Re: RomPirate's new-new-new-new car
Noice. Another Mazda in the fold. I've always been intrigued by the RX-8 but don't know that I would do it justice.
RomPirate wrote:Well, new to me at least.
Ah yes, I did the same thing. I haven't touched a thing since I bought it though.
Looks like a fun project. Do you have a garage?
yo, how's dat s60 treating you?? up for a meat up soon?? :) :twisted:
RomPirate
Post by RomPirate »
I have a 1 car garage (miata lives in it) for three cars + wife's. The Rx8 is on jackstands off to the side.
So I purchased a rotary compression tester (rotarycompressiontester.com) compression is poor! Cold: 66 PSI @ 226 RPM == ~73 PSI @ 250. Compression can only be lower when engine is up to operating temperature. Haven't even tried to start it due to a leaky fuel pump. Dropping in a new pump this weekend and will try to start it. My expectations are low :cry:
07 VW Rabbit
05 RX8 (Sold!)
95 Wrangler
RomPirate wrote:I have a 1 car garage (miata lives in it) for three cars + wife's. The Rx8 is on jackstands off to the side.
You need to talk with our resident rotarian: Nube-5Zillion. F N he don't know it, nobody does.
RomPirate
Post by RomPirate »
It's been a while.
Long story short, i've replaced the engine with a Mazda re-manufactured unit. Word on the street is that these units are actually 95% brand new. It shows.
Image The only thing that looks used is the engine hangar. New flywheel, water pump etc... nice.
Pulling the old engine was pretty easy. Here is a shot I have of the old lump.
The engine is quite small. Displacement is 1.3L. HP is about 220-238-250 depending on what mazda felt was appropriate at the time. Redline is 9000 RPM :shock: Fuel economy is "around 20mpg". Thing runs on gasoline and oil. Really. Fun fact: Gearing between the rotor ("piston") and eccentric shaft ("crankshaft") is such that the shaft rotates 3x for every rotor rotation. @9k RPM, the rotor is only rotating 3k RPM. Every revolution of the rotor has 3 power strokes.
Up-up and away! After years of automotive tinkering, one collects lots of tools. The heaviest of tools is an engine hoist which has helped replace transmissions, remove engines and replace engines (here).
So much space for a V8... I considered a V8 swap but my fabrication skills wouldn't be sufficient. If they made a bolt in kit, i'd do it.
Here is the old engine resting. Story goes that the engine had been replaced at least once, probably with a junkyard engine as crappy dealerships do for warranty.
Inside scoop of said garage. Packed to the gills. Miata for reference. Humble toolbox with lots of tools.
Here are both of the engines lined up, ready for transplant. Protip: Put phone in a ziplock bag to keep it clean. Makes for fuzzy images.
Few hours later...
Closeup shot. Clean as you go....
ooooo
lets go!
07 VW Rabbit
05 RX8 (Sold!)
95 Wrangler
RomPirate
Post by RomPirate »
Unfortunately no images of the install. Install is the reverse of removal. Except 100x more difficult cause everything has to line up.
Also, the waterpump gasket is phallic in nature.
07 VW Rabbit
05 RX8 (Sold!)
95 Wrangler
But what if you move it away from nature and into the concrete jungle?
RomPirate wrote:Also, the waterpump gasket is phallic in nature.
Looks like something the Navy would draw in the sky with an airplane. :lol:
RomPirate wrote: So much space for a V8... I considered a V8 swap but my fabrication skills wouldn't be sufficient. If they made a bolt in kit, i'd do it.
Drats!! Eye was hoping for a 2.5 litre swap!! :o :? :cry:
a 2.0 liter skyactiv swap :wink:
bk7794 wrote:a 2.0 liter skyactiv TURBO swap :wink:
thickset
