mtheis's 1995 Toyota Tercel
- wannabe
- Cars: NONE - take the bus
Re: mtheis's 1995 Toyota Tercel
i've never opened my hood...how does it open????
- Cars: Mazda3, Matrix, R3
That's clean! Nice car!
(I didn't know they still had the 4 speed MT on that generation Tercel...)
- mtheis
- Cars: 07 Corolla, 76 Celica
There's a lever inside under the dash on the left to pop the hood... then you lift the release lever under the middle of the hood to raise it.wannabe wrote:i've never opened my hood...how does it open????
2007 Corolla
2017 Cannondale Quick 3
1995 Tercel
1976 Celica GT
Unofficial SS.com IRC Server
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
- wannabe
i'll have to do that later...thanks
Have you checked valves, lifters etc? How's the oil holding up? The 91 Tercel I almost bought was losing oil due to stuck lifters.mtheis wrote:It's been having minor issues since I hit 150k. Most recently I've gotten some slight engine pinging. In the past week I've replaced the spark plugs, wires, oxygen sensor (needed to be replaced anyway), and cleaned the EGR valve. Nothing I tried seemed to fix it. I might try cleaning the MAF sensor and replacing the fuel filter and thermostat whenever I have enough money.
I'll be checking for vacuum leaks and testing the fuel pump and injectors too.
- padauk_dust
- Cars: '88 Accord, '96 VFR
potownrob wrote:Have you checked valves, lifters etc? How's the oil holding up? The 91 Tercel I almost bought was losing oil due to stuck lifters.mtheis wrote:It's been having minor issues since I hit 150k. Most recently I've gotten some slight engine pinging. In the past week I've replaced the spark plugs, wires, oxygen sensor (needed to be replaced anyway), and cleaned the EGR valve. Nothing I tried seemed to fix it. I might try cleaning the MAF sensor and replacing the fuel filter and thermostat whenever I have enough money.
My Miata was using quite a bit of oil and had loud lifter tick sometimes, especially when the oil was getting near time to change.
Seafoam in the crankcase helped quite a bit.
'88 Accord DX
'96 VFR750
'96 VFR750
- mtheis
I took 3rd gear up to redline repeatedly last week and that seemed to clear up the engine pinging. I'm also switching to 10W30 (was using 5W30) to help with the oil consumption.potownrob wrote:Have you checked valves, lifters etc? How's the oil holding up? The 91 Tercel I almost bought was losing oil due to stuck lifters.
2007 Corolla
1995 Tercel
1976 Celica GT
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
Not sure if changing to 10w30 is the best idea, though it will probably help with oil consumption. Have you tried a high mileage oil like Valvoline MaxLife? That used to help a lot in my Civic and Accord. Not sure how the newer MaxLife is, since it's now a synthetic blend instead of full dino oil with additives.mtheis wrote:I took 3rd gear up to redline repeatedly last week and that seemed to clear up the engine pinging. I'm also switching to 10W30 (was using 5W30) to help with the oil consumption.potownrob wrote:Have you checked valves, lifters etc? How's the oil holding up? The 91 Tercel I almost bought was losing oil due to stuck lifters.
I'll second that -- stick with the right viscosity rating, and get a "High Mileage" oil. If your engine isn't designed to move thicker oil around, it may not move the oil well enough.
- wannabe
how do you figure out what kind of oil ur car is supposed to have, in the first place?
and DON"T tell me to look in the owners manual, i don't have one.
Lots of cars are marked with the proper oil weight on the oil cap. Your 1992 Tercel probably takes 5w-30. You could email Toyota or ask a Toyota dealer service department.
it doesnt matter. cant go wrong with 5w30
im running rotella T 5w40 in mine, good cold viscoucity and thick enough to lubricate at high rpms and high heat. probably gonna run 0w50 in my turbo engine or if i yank and refresh my engine this summer.
- comingbackdown
Get a service manual.wannabe wrote:how do you figure out what kind of oil ur car is supposed to have, in the first place?
- mtheis
The only reason I'm reviving this thread is because I'm drunk off my ass. I have no valid reason to use 5W30 since I moved back south. It doesn't get cold enough here. I still have engine knock and I'm switching to 10W30 sometime this week. I use the cheapest oil too. You know what? My car can handle it. I do have a stuck lifter but I don't care right now.
Ok no more drunk postings tonight. I can see daylight through my bedroom window and I have a f**k exam tomorrow.
2007 Corolla
1995 Tercel
1976 Celica GT
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
- wannabe
where do our cars redline at? i wanna make a paper tach.
