Thanks man.eaglecatcher wrote:Gorgeous wheels
Can you really fit 285's up front? That's pretty beastly compared to what my SN95 was capable of, something like a 245 is the widest you could have up front without rubbing
You can run some monsters on the S197 Mustang. But, if you're running big tires in the front, it helps to have caster/camber plates installed, especially if lowering the car a bit (and pretty much anyone bothering to put tires that large on all four corners will be adding c/c plates due to changing out the struts too.) There are S197 guys with ten-inch wide front wheels running 305s in front, but that takes a bit of massaging that I'm not up for. And a lot of money that I don't have.
That said, I did misspeak/mistype. I'll be going 275/40/18s, possibly 275/35/18s, due to greater tire choices, tire affordability, and to avoid rubbing.
