Check out my Lincoln, in Lincoln NE!
- ihartmacz
I got a bargain on Craigslist for this 1991 Lincoln Continental ($250). I am going to park the Mustang for the winter and drive this little bastard when it starts getting bad outside. I already love it; it runs pretty well. Brand new tune up (new wires, cap, rotor, and plugs), new tires, and a tape deck adapter for MP3 players... NICE
It's got the same 3.8L V6 that's in in my Mustang (no electronic ignition), so how can I go wrong. My Mustang is one dependable bitch.
The bad:
-ABS doesn't work
-Rusty
-Auto tranny (works well!!!)
The gauges look better than that, it's the phone's camera.
I love this interior...
The bad:
-ABS doesn't work
-Rusty
- Cars: Mustang GT
Re: Check out my Lincoln, in Lincoln NE!
You posted this a few minutes ago, have you sold it yet?
i liek lincolns
i liek lincolns
Duuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuude I want that. For $250 that is awesome. I wish I could find and buy deals like that.
Can't be. No way it's got points and condenser. My 1980 Buick has electronic ignition. It's not a modern distributorless computer-controlled electronic ignition, but it's not like we're dealing with a magneto. AFAIK everything since the 1970s has electronic ignition.ihartmacz wrote:(no electronic ignition)
Bummer.The bad:
-ABS doesn't work
-Rusty
- DarkPilot
I'm sure you can hack a fine manual gearbox on there somehowihartmacz wrote: The bad:-Auto tranny (works well!!!)
Maybe a few forumites can give you some advice on where to start.
Should be easier than my project was.
- Cars: 1986 Mazda RX-7 x2
Convert it to RWD and put an LS1 in it.
Looks like it would make a great beater, though. Hell of a deal.
Wait, it's fail-wheel drive? I didn't know that. I retract my statement about it being easier to convert. I don't know how to do it for FWD.
- FDSpirit
- Cars: 2000 Honda Civic Si
How the hell do you keep getting these killer deals?
- ihartmacz
I should have said the Lincoln has no DIS.theholycow wrote:Can't be. No way it's got points and condenser. My 1980 Buick has electronic ignition. It's not a modern distributorless computer-controlled electronic ignition, but it's not like we're dealing with a magneto. AFAIK everything since the 1970s has electronic ignition.ihartmacz wrote:(no electronic ignition)
I remember working on a VW Scirocco from the late 70's and it still used poince-n-condescenders and a carburetor with a non-functional float valve (well, maybe they ALL didn't have non-functional float valves, but this one did. Fuel overflowed the float chamber and splashed on top of the closed throttle plates at idle.
- ihartmacz
I don't like carburetors, I think they suck.Rope-Pusher wrote:I remember working on a VW Scirocco from the late 70's and it still used poince-n-condescenders and a carburetor with a non-functional float valve (well, maybe they ALL didn't have non-functional float valves, but this one did. Fuel overflowed the float chamber and splashed on top of the closed throttle plates at idle.
Yeah, I should have been more clear. The Lincoln doesn't have points, it has a new style distributor with an external coil. It also has one of those external starter relays. Damn old fashioned Ford. It will be so reliable. I wish it had DIS, but it doesn't.
Today my mom said: "I would trust a Chevy to start when it's cold more than a Ford. Just saying..." I gave her a weird look because it was just something I wouldn't expect a Jeep girl to say... I'm expecting good reliability out of this car. It runs smoothly and has a ton of response, doesn't leak coolant, new tune up, new struts all around, and tons of tune-up stuff.
So, the car originally came with air-ride, but the previous owner put conventional struts on all four corners! He said that the 1993s had the option of conventional struts or air ride.
- mtheis
- Cars: 07 Corolla, 76 Celica
How many cars have you had?
2007 Corolla
2017 Cannondale Quick 3
1995 Tercel
1976 Celica GT
Unofficial SS.com IRC Server
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
Word!ihartmacz wrote:I don't like carburetors, I think they suck.
What are the advantages of an internal solenoid? Like an external clutch slave cylinder, an external starter solenoid is much easier and cheaper to replace...but unlike an internal clutch slave, I can't guess the advantage of an internal starter solenoid.It also has one of those external starter relays. Damn old fashioned Ford.
What is DIS? Distributorless Ingition System?It will be so reliable. I wish it had DIS, but it doesn't.
My first car was a beat-up Cadillac that had air ride. Sometimes a "Car is leveling" light would illuminate on the dash and sometimes I could hear the compressor running but it never actually worked.So, the car originally came with air-ride, but the previous owner put conventional struts on all four corners! He said that the 1993s had the option of conventional struts or air ride.
I rerouted the air lines to schraeder valves in the trunk and pumped them full of fix-a-flat as preventative measure, then went to the gas station to air up. I got the rear of the car way up in the air. Then I left the gas station and went down into the street, as the lot there was raised. As the rear wheels hit bottom the stuff went "SPLAT"...leaving a puddle of fix-a-flat on the road and my car's rear end sagging once again.
MASSIVE pet peeve. Its not a solenoid. Its an obese relay. Solenoids convert electricity to mechanical action.theholycow wrote:What are the advantages of an internal solenoid? Like an external clutch slave cylinder, an external starter solenoid is much easier and cheaper to replace...but unlike an internal clutch slave, I can't guess the advantage of an internal starter solenoid.It also has one of those external starter relays. Damn old fashioned Ford.
