Projekt Mordecai/MRDRMBL/Das Großer Benz
Re: Projekt Mordecai/MRDRMBL/Das Großer Benz
1974Alfa5spd wrote:
Rope-Pusher wrote:Put some big ball bearings in a metal can and wire it to the engine so it sounds like a diesel!
Wouldn't work, engine's too smooth. :mrgreen:
Too smooth? Of course it's too smooth, it doesn't run, right?
If you find the replacement engine is also too smooth, try giving it a vacuum leak. I bet you could rug up something that is tuneable for just the right amount of leakage to give you that great pockety-pockety sound at idle.
Too much work. Just get a whistle tip. It goes wooWOOO!
theholycow wrote:Too much work. Just get a whistle tip. It goes wooWOOO!
Sure, whistling to simulate a turbo spooling up, but you still need to get the idle sounds right.
Oh, and put a little diesel in the muffler to get the aroma and the particulates correct.
1974Alfa5spd
Post by 1974Alfa5spd »
Today has been a long, exciting day. :mrgreen: Left around 11:45 to go get the trailer, after forgetting the tow chain and jumper cables, we made it out on the road to Fremont at about 12:30. Couldn't find the fuel pump relay, so we couldn't get the engine started, so all four of us were behind it pushing as hard as we could (giggity). Eventually, we reached an expected point where we couldn't push it anymore, so we hooked the front tow eyelet to the truck and tugged it onto the trailer. Drove it home, put it next to the driveway, and proceeded to go to town on it. Cleaned off the horrendously worn paint, put some fresh painters tape on the window that won't go up, and made a video. :mrgreen: Got out the pressure washer, sprayed industrial strength degreaser all over the place, and sprayed the engine bay clean. Then dad came home with some armorall cleaner, and got the interior cleaned up, pulled out 20 years of garbage from under the rear seat (pics to follow), got it cleaned off, and put it back together. :mrgreen: It no longer smells like smoke for the most part (getting a rug cleaner tomorrow), and it feels very German and executive-y. I like it.
1974Alfa5spd
Story of what I found:
All 20 years of crap under the seat, someone's mom owned this thing.
Even found a set of keys! Must've been to some house, she was a realtor (found about a trillion of her cards under the seat).
And a quick lo-def tour. I got my new 720p pocket cam working again, so I'll take a new one tomorrow. Got too dark.
noob5,000,000
Cars: 1986 Mazda RX-7 x2
Post by noob5,000,000 »
Niiiice.
94Corolla5Speed
Post by 94Corolla5Speed »
Can't wait to see this thing shiningly clean and running
DKaz
Cars: Mazda3, Matrix, R3
Post by DKaz »
Ew gross! Can't wait to see this beautiful car cleaned up.
09 Mazda 5 GS 6MT - His
12 Mazda 3 GS-L Skyactiv 6MT - Hers
1974Alfa5spd
So, dad went and bought a new battery this morning, in the process of removing the battery tray so we could treat the rust on it, we damaged an o-ring on the washer reservoir, causing it to leak washer fluid all down the street, and we also found that the washer reservoir has a coil that has hot engine coolant pumped through it so that when it's cold as tits outside, your washer fluid will thaw. Got the battery tray all treated and painted, dropped in the new battery, and it cranks like crazy, but no spark. (FFFFFUUUUU-) I smell gas, the fuel pump is humming, but I think dad may have fuxxord the coil when he hit it with 1750PSI of water without the cover on it, which we found sitting about a foot away from it.
Would you wash yourself with 1750 PSI water? Shirley you shouldn't wash a new baby like that!
1974Alfa5spd
Just went out and did a test. The coil's potentially still good, just no power to it.
For God's sake, you got to give more power to the coil
For God's sake, why don't you give more power to the coil?
For God's sake, got to have it, more power
For God's sake, got to have it, power, power, power
For God's sake, you better give more power to the coil
For God's sake, why don't you try it? Yeah, power, power
For God's sake, can't deny it, no, no, no, power, power
For God's sake, why don't you give power, power?
For God's sake, you got to give....
1974Alfa5spd
Quick few pictures I took this morning:
Easily a four body trunk:
Screwed up battery tray:
And all the gunk we found below it:
Better photo of the motor:
That's the washer bottle sticking up. Have to remove that to get the battery tray out.
After all my dads hard work getting the decals off:
And an even betterer picture of the motor:
Lol factory cold air intake:
In its old and nasty condition, that still looks cleaner than anything I've ever owned, even when it was brand new.
Rope-Pusher wrote:For God's sake, you got to give more power to the coil
I'm giving her all she's got, Kipt'n!
1974Alfa5spd
And a couple of videos, now in HD!
