Project RA24 Celica
- mtheis
- Cars: 07 Corolla, 76 Celica
Project RA24 Celica
Original thread here.
Car: 1976 Toyota Celica GT. My brother bought it in 1986 and sold it to me a few days ago. It has ~230,000 miles on it. It's also been parked for the last 13 years.
Plan: 20R/22R "hybrid" motor (Google it) with dual carbs and a close-ratio 5-spd. I have 99% of the parts needed.
Expected difficulties: I've never done half of this stuff before.
It kinda resembles a ladybug with all of the rust spots on the hood.
Perfect for heel-toe.
This is the original 20R block that will be discarded.
In the trunk we have a dead bod- nevermind...
It's actually the 22R block that will be going under the hood.
The cylinder head and transmission that I'll be using.
Clutch.
Two cobbaraydas.
Gaskets for pretty much everything.
And I'll be doing lots of reading.
Clutch.
Two cobbaraydas.
2007 Corolla
2017 Cannondale Quick 3
1995 Tercel
1976 Celica GT
Unofficial SS.com IRC Server
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
Re: Project RA24 Celica
I like some of that interior, the dash, steering wheel, door panels, and floors.
What's the switch panel looking thing under the left side of the dash?
Why not fuel injection? Because you already have carbs? Fuel injection should be easy and inexpensive for that engine.
- mtheis
That switch panel is actually the fuse panel. I'm sure fuel injection would work, but I've heard that the power gains are negligible with this particular setup. The 20R never had it and the 22R engine parts I have are different than the newer 22R/22RE. Maybe this car will see a 22RTE (turbo) swap at some point.
2007 Corolla
1995 Tercel
1976 Celica GT
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
That's a nice place for a fuse panel. Mine is horrible, I wish I could relocate it. It's up against the firewall above the dead pedal.
Are you going to look to replace the hood? Or just recoat against rust?
- mtheis
The hood only has surface rust and will be repainted along with the rest of the car if I can find the paint codes. There are a few places where I'll need to weld in some new panels first.
2007 Corolla
1995 Tercel
1976 Celica GT
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
Will you do your own welding? Do you have equipment and experience?
- mtheis
Negatory. I will most likely have someone else do the welding.
2007 Corolla
1995 Tercel
1976 Celica GT
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
This is sweet. I look forward to seeing the progress.
What kind of rebuild are you planning with this car? Full restoration, where the car will look completely new when you're done? Or just fix it up and drive it rebuild? Or maybe somewhere in the middle?
- mtheis
This will be a fix it up and drive it rebuild with a paint job at some point.
2007 Corolla
1995 Tercel
1976 Celica GT
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
- Cars: 1986 Mazda RX-7 x2
Neat!
94Corolla5Speed wrote:noob5,000,000 wrote:Neat!
I yam imagining a Frankenstein moment: "It Lives!"
Maek shur U brush the rust off the input shaft splines and then lube them B4U slip on the clutch.
