i followed the "ranger clutch fluid change technique" (outlined here http://www.rangeracceleration.com/Clutch_Care.html)
which essentially was where you clean out your clutch reservoir, put in new dot3 fluid, pump clutch pedal 30 times, check if fluid is dirty, then repeat process until clean.
i did this about 10+ times and the fluid is still dirty...
im having severe clutch pedal issues (pedal wont return, pedal stuck midway, cannot engage ANY gears b/c pedal is stuck!), but it seemed to fix the problem temporarily.
should i keep reflushing it?? or take it to the mechanic?
im thinking of bleeding the clutch system..but i dont know if this will fix it longterm or short term..
replacing clutch fluid
1987 Nissan 300ZX N/A
Re: replacing clutch fluid
I have no idea why you did that in the first place...
Bleeding should've been the first thing to do, not pumping new fluid in and checking.
do you think bleeding my clutch lines will fix the problem??
or do u think i need a slave cylinder to be replace (or even..the master cylinder??)
Well, bleeding you clutch (PROPERLY!) is the first step to diagnose any kind of hydraulic problem:
Post #14, DaIntegra shows the proper way to bleed a clutch:
http://www.honda-tech.com/showthread.php?t=479958
