Auto slipping out of gear???
Hi there,
Since you guys helped me so much with my last problem I was wondering if I could call upon you once again...
My mum has an automatic 2004 Ford Focus, It's only done about 90,000kms.
When shes in "Drive" she says it sometimes slips out of gear, as if it were in neutral. (engine revs and revs and the car goes no where fast)
She says that it doesn't happen when she uses the overdrive button but she doesn't want to have to drive around with "high revs" all the time.
Does any one have any ideas as to what might be the cause of this?
Her friend said it could cost a few thousand to fix and shes a bit worried about it.
I don't know a lot at all about automatic transmissions so any advice/input at all would be greatly appreciated.
Thanks a lot guys!
Much love for this forum.
Thanks a lot guys!
~ shaolin.
Re: Auto slipping out of gear???
Probably a good first step would be to check trans fluid level. Also, smell the dipstick - does it smell burnt? If the fluid isn't low, get some estimates on what a repair or replacement would cost.
Also, check with a Focus or Ford forum and try to learn how prevalent this problem is and what other folks have done about it in their situations.
What is her duty cycle? Does she drive a lot of miles at expressway speeds? If she doesn't, the most cost effective solution might be to continue driving it with Overdrive disabled. If she can avoid paying for a transmission replacement or rebuild, the cost savings would pay for a lot of gasoline. I would be surprised if it boosted highway fuel economy by 5 MPG, but compare her yearly mileage driven divided by average fuel economy times fuel cost per gallon against yearly mileage divided by 5-less mpg times cost of fuel. Multiply this difference by the number of remaining years she plans to own the vehicle. Compare this figure with the cost estimate to correct the condition.
mIf some family member could volunteer to donate the labor, it might make it worth her while to fix it.
If the problem is rare, consider buying an experienced trans from a junkyard. If they all do it, junkyard trans is likely to have the same issues and a good rebuild might address the root cause of the problem.
- VTECaddict
yep, check ATF level first. when was the last time ATF was changed?
2006 BMW 330i 6MT
- Cars: 98 s-10 4.3L vortec v6
if its not the fluid level it prolly needs a rebuild and if it's starting it might go fast mine started acting up and within 3 miles stopped working completely. then again it might just be the overdrive like rope-pusher said compare the costs
^ I had a GOOLIE slushbox where lock-up torque converter sometimes stayed locked. It was odd to brake to a jerking halt when instincts said "Stab the clutch pedal, Dummy!" After the engine stalled, I would shift into Neutral and restart. Then, I had to give it some throttle and neutral-slam into gear to get going again. After this rude treatment, the TC clutch would usually get shaken open and things were OK until I reached lock-up speed again. I looked into it and decided unplugging the electrical connection that controlled the TC clutch was the most cost effective solution.
Best part about living through this was the perverse joy I felt seeing other GM FWD car drivers having the same problem. I wonder if cancer survivors feel the same way about newly-diagnosed cancer patients.
You guys are the best. Thank you so much for your replies.
I'll check out the transmission fluid and get back to you
Thanks!
Thanks!
~ shaolin.
- kamesama980
+1 for fluid level low or time for a new box. sounds exactly like when I burst a ATF cooler hose and it drained. rev it up and it builds enough pressure in spite of aeration to hold the gear clutchpacks but if not, you go nowhere fast like you're in neutral.
-Russ
1990 Toyota Cressida 3.0l M5
1994 Pontiac Firebird LT1 M6
1970 Volkwagen Beetle M4
1990 Suzuki VX800 SM5
- comingbackdown
LULZ!Rope-Pusher wrote:^ I had a GOOLIE slushbox where lock-up torque converter sometimes stayed locked. It was odd to brake to a jerking halt when instincts said "Stab the clutch pedal, Dummy!" After the engine stalled, I would shift into Neutral and restart. Then, I had to give it some throttle and neutral-slam into gear to get going again. After this rude treatment, the TC clutch would usually get shaken open and things were OK until I reached lock-up speed again. I looked into it and decided unplugging the electrical connection that controlled the TC clutch was the most cost effective solution.
TCC Lockout Solenoid. I've seen that at least three times thus far in my lifetime! Funny thing is, most people pay the $300+ to have it replaced, when you can just unplug the damn thing...
- mtheis
- Cars: 07 Corolla, 76 Celica
Yes, but then the transmission can overheat while driving at highway speeds.comingbackdown wrote:TCC Lockout Solenoid. I've seen that at least three times thus far in my lifetime! Funny thing is, most people pay the $300+ to have it replaced, when you can just unplug the damn thing...
2007 Corolla
2017 Cannondale Quick 3
1995 Tercel
1976 Celica GT
Unofficial SS.com IRC Server
Official lurker
1995 Tercel
1976 Celica GT
Official lurker
Agreed. Also, you then get "slush" behavior all the time, wasting gas and power. Might as well spend the money to fix it.mtheis wrote:Yes, but then the transmission can overheat while driving at highway speeds.
^Slushbox cars were around for years and years until Chrysler reintroduced the lock-up torque converter clutch in the late 1970s. I do agree that it should run a bit hotter w/o lock-up, but that's not touche that it will overheat. Michigan is not mountainous and not the hottest place on earth, so my driving w/o lock-up didn't push the envelope of the cooling system design.
