2005 Dodge Neon electrical problems
noob5,000,000
Cars: 1986 Mazda RX-7 x2
Post by noob5,000,000 »
This is my brother's 2005 Neon. One day his car wouldn't start, so we towed it home, and found a wire knocked off the starter. We reattached it and then it started, and has done so reliably since then. But, after that, The airbag lights is constantly on, none of the HVAC stuff works, the power windows don't work and the reverse lights don't work
We're basically stumped on this, any help is appreciated.
fa22raptorf22
Cars: 2004 SSM Acura RSX
Re: 2005 Dodge Neon electrical problems
Post by fa22raptorf22 »
Looks like maybe the wire when loose hit a ground and popped a fuse?
Check them and get back.
noob5,000,000
We've checked all the fuses and none of them are blown. I guess I should also add that it's an SXT 2.0 4-cyl.
mtheis
Cars: 07 Corolla, 76 Celica
Post by mtheis »
noob5,000,000 wrote:This is my brother's 2005 Neon.
It's a Dodge. What did you expect?
2007 Corolla
2017 Cannondale Quick 3
1995 Tercel
1976 Celica GT
Unofficial SS.com IRC Server
Official lurker
Try disconnecting the battery for a few minutes and reconnecting and see if anything resets.
Starter leads don't just fall off on a 4 year old car - even if it was only finger tight when built, there would be enough corrosion on the threads from 4 years of environmental exposure to stop it from coming undone by itself. Did someone play with it recently?
noob5,000,000
Rope-Pusher wrote:Try disconnecting the battery for a few minutes and reconnecting and see if anything resets.
It wasn't one of the main cables, it was just a small gauge wire that clips on to a prong on the starter.
Another thing worth mentioning, my dad did some research and asked a question on one of those 'pay for a mechanic to answer a question' things. He mentioned a fusible link in one of the wires coming off the starter, and if this link is tripped it could cause all that stuff to go out. But we were messing around with it today and it didn't appear to be blown.
Well next time we have the car in our hands (my brother recently moved out, so its kind of a pita to even look at the car) I'll look closer at it. It's nigh impossible to get to (those r-tards put the starter and crap directly under the intake manifold) maybe we just weren't getting the right grip on it to inspect it properly r something.
Disconnecting the battery can trigger a reset of the confuser. Never hurts to try.
Yes, fusible links are used to protect circuits before they are protected by fuses or breakers, like the alternator wiring. I had to replace one once. It just seems odd that starter is functioning now if loose wire caused fusible link to blow when it shorted on sumpin. Did you check to see if the wiring to the reverse lamp switch was taken out by the same something that knocked the starter solenoid wire off? Ever see picture of the guy with the big snake living under his hood?
comingbackdown
Post by comingbackdown »
*BUZZ* Wrongo. I personally have never had any serious problems with Dodge...
However...
Hmm... "Neon".
Well, SHIT! There's your friggin' problem!
noob5,000,000
Resurrecting for lulz, we finally gave up and took it to a shop, they eventually discovered a 'bad wire'. Everything works now, winnar.
