Clutch engagement point changed
Re: Clutch engagement point changed
Eric1285 wrote:I see. Any chance that an air bubble would work itself out or will the system have to be bled?
Again, as RP said (in the exact same post), it could have worked itself out which is what caused the pedal height difference.
Rope-Pusher wrote:Could it have had an air bubble in the hydraulic clutch release system that finally worked it's way up the tube and got out to the fluid reservoir? That would make a big difference in the engagement point and yet not be due to any other mechanical problem.
To further clarify: It is possible that you had a bubble before and it's gone now.
