Car wobbling while braking
FDSpirit
Cars: 2000 Honda Civic Si
Re: Car wobbling while braking
Post by FDSpirit »
As per google search...somewhat. Valucrap=Valucraft. I've seen it around, but never actually seen anyone purchase it.
Valucraft is the lowest of the low products that we sell at Autozone. Roughly equal to making car parts out of mud and twigs. Next step is Duralast, which is on par with OEM. Following that is Duralast Gold, which exceeds OEM standards. Finally (for brake pads only) comes Duralast Gold CMAX, which are ceramic and expensive
LHOswald
Cars: '99 Civic Hatch w/B16a
Post by LHOswald »
watkins wrote:Finally (for brake pads only) comes Duralast Gold CMAX, which are ceramic and expensive
and probably stop on a dime
Nah not really though I rarely hit the brakes all that hard. Theyre nice and quiet and clean though. Im not going to complain about purchasing them.
rubi
Cars: Citroën AX
Post by rubi »
At first I only felt it in the vehicle shaking, it felt like I was running over bumpy pavement. Then it got worse and I felt it in the brake pedal.
Exactly! Last week I was driving on an extremely bumpy road and the vibration were inexplicable compared to the cars around me and then I noticed it's always wobbling when braking especially on higher speeds, and there's excess vibration.
Another question how does that affect other parts or it doesn't?? I am gonna fix it next week but I am curious.
Warped brake rotors shaking the vehicle could conceivably rattle other stuff enough to cause premature wear on wheel bearings, shocks, and front end parts.
There is a possibility, though unlikely, that it's something other than warped brake rotors. Because at first mine couldn't be felt in the pedal I tried to find out what else it could be. The same list I gave above (wheel bearings, shock absorbers, front end parts) could be the cause if it's not your brake rotors.
fa22raptorf22
Cars: 2004 SSM Acura RSX
Post by fa22raptorf22 »
theholycow wrote:You have a brake lathe? Is that an affordable investment for a DIYer?
If you find an older one, or inherit it...yes it is.
Also, for pads. Ceramic Adaptive One pads are some of the best oem replacements that I have used. They are sold at places like Napa. Although they make a bit of dust, they have superior stopping power and are quiet. I mean, totally silient.
Also,
theholycow wrote:Warped brake rotors shaking the vehicle could conceivably rattle other stuff enough to cause premature wear on wheel bearings, shocks, and front end parts.
Warped brake rotors are the death of the caliper guide pins and clips!!!!
FDSpirit
Post by FDSpirit »
Is there a place to drop off used brake fluid? Never seen it posted in the auto stores.
FDSpirit wrote:Is there a place to drop off used brake fluid? Never seen it posted in the auto stores.
Yes, in a half-empty bottle of laundry bleach!
I had some bad Michellin tars wunce that wobbled at low speeds when cold. Didn't trust them much at higher speeds when I found out that they were experiencing "belt migration"
Image Image Image
rubi
Cars: Citroën AX
Post by rubi »
I am starting to think it's a mount, it vibrates even when i am not moving now!!
rubi wrote:I am starting to think it's a mount, it vibrates even when i am not moving now!!
Put the trans in Neutral. If the wobble / vibration continues, it's not the powertrain mounts.
rubi
Cars: Citroën AX
Post by rubi »
Well the car shakes in neutral or at low rpm, it kinda wobbles, more like the dashboard is shaking and i can feel it in the gas pad...
Does it smooth out if you raise the RPM from idle and hold it steady at that higher RPM in neutral?
