car stops while decelerating
FDSpirit
Cars: 2000 Honda Civic Si
Re: car stops while decelerating
Post by FDSpirit »
If its a dirty TB, you can buy spray to correct that problem.
michaelchen
Cars: 1995 Subaru Legacy
Post by michaelchen »
http://minimopar.knizefamily.net/idleproblems.html
I am so convineced by this page that my problem is a dirty throttle body problem, cann't wait to clean it. I will come back to tell you nice guys about the result.
Clean your IAC
michaelchen
Just cleaned the TB, and drove around, experienced a stall at turning!!!
So start to clean IAC, however I cannot find IAC on my 95 Subaru Legacy. Can anyone point to me which one is the IAC?
You do not have the required permissions to view the files attached to this post.
michaelchen
I removed the cap of "B" part, and it doesn't look like a IAC.
Further, there are so many springs attached to the right side of the TB body. how can I remove the TB body for cleaning?
I think "A" is TPS - Throttle Position Sensor.
Try B - Ref: http://images.google.com/imgres?imgurl= ... G%26um%3D1
michaelchen
The second picture show what B looks like after remove its cap. There is only a shining metal stick. Nothing to be cleaned there.
I think the more important step for me now is how to remove the TB. I don't know how to deal with its springs at the right hand side. These springs links to the gas pedal,and are quite delicate (see the photo in my previous post)
Tinton
Cars: 91 MR2t, 88&86 Fieros
Post by Tinton »
Downshifting and leaving it in gear when you go through corners = problem solved. Its proper driving technique, you should learn to do it anyways. If your car has a rough idle and sometimes it dies while trying to idle (car stopped) you should look at cleaning out the throttlebody and any sensors near it, like TPS and IAC. Honestly it sounds like your IAC gets stuck sometimes.
