What's wrong with my car??? Help fellow standard shifters!
Re: What's wrong with my car??? Help fellow standard shifters!
well what i consider beating on is much less than what other people consider beating on >.<
- fa22raptorf22
- Cars: 2004 SSM Acura RSX
Beating on for me is defined by: 1)Knowingly abusing the vehicle by running it long and hard (not what she said) and/or not maintaining it. 2)Unknowingly causing damage to parts of the car due to lack of knowledge.LHOswald wrote:well what i consider beating on is much less than what other people consider beating on >.<
If you are doing hard launches and redline shifts, this does NOT mean you are beating on the car. You can be running it hard, and at the same time being mentally aware of what you are doing, and doing the proceedures at hand correctly
- Bawked
A street car needs little work generally, turbo cars need more work as they are being pushed more..... The harder you drive a car and the more power you put down the more work the car needs. Drag cars that get rebuilt after every meeting is the extreme of this.
If you are putting out 100ft/lb more than stock then you better bet it's going to need more regular maintenance, also higher quality parts to stand up to the higher stresses. I don't think beating on a car is bad... if its stock let the oil temp get to spec then go for it, stock cars are usually tuned safely. You make it more powerful than stock.... then make sure enough water is going through the engine, that the engine is getting enough fuel at the top end, etc... Beat on the car, enjoy it but the further you go past stock power the more maintenance and the higher quality parts you'll need to keep the car running at it's best.
My car is completely stock except for a useless intake someone decided to put on it, so as long as I stick to the maintenance toyota recommends then I feel just fine "beating" on it. I check things regularly though and try fix problems before they put my car at risk.
But you have to pay to play.
<3 fwd
my buddy just got a whale penis on his mr2t. he swears he got a 10hp gain just from the amount of air he's getting now. i haven't driven with him in it since he installed it, and im skeptical at best
LHOswald wrote:my buddy just got a whale penis on his mr2t. he swears he got a 10hp gain just from the amount of air he's getting now. i haven't driven with him in it since he installed it, and I'm testicle at best
- mesaboogie18
- Cars: 2004 VW GTI 1.8T 5speed
I don't consider it beating on my car...more like pushing my car. I treat her well and she has nothing but top quality aftermarket parts added to her.
Vdub tuner drove the car and as soon as he pushed the clutch in told me it was gone. Drove it and saw the symptoms: Clutch is on it's way out for sure. Said I could drive it like this for a good bit longer as long as I go easy on her, until I can save up the $$$ for the higher performance clutch kit. The reason it won't shift is b/c the clutch is slipping and not fully disengaging fast enough.
2004 VW GTI 1.8T
That part doesn't make sense. When you step on the pedal, it pulls the clutch away from the flywheel. It doesn't matter if it would be slipping when it's touching or not, because it's not touching.mesaboogie18 wrote:The reason it won't shift is b/c the clutch is slipping and not fully disengaging fast enough.
i think i brought this up before but i can't find it. oh well.theholycow wrote:That part doesn't make sense. When you step on the pedal, it pulls the clutch away from the flywheel. It doesn't matter if it would be slipping when it's touching or not, because it's not touching.mesaboogie18 wrote:The reason it won't shift is b/c the clutch is slipping and not fully disengaging fast enough.
the only thing that would cause a clutch to not disengage (when the pedal isn't stuck) is either the hydraulic system is leaking, worn seals or just old and crapped out. if its a cable clutch, then the cable is stretched.
or maybe there is gum on your clutch. TRY SLIPPING IT MOAR!!
- mesaboogie18
Nah, it's 100% the clutch and I'm replacing it with a stronger clutch/lightened flywheel. Can't wait!LHOswald wrote:i think i brought this up before but i can't find it. oh well.theholycow wrote:That part doesn't make sense. When you step on the pedal, it pulls the clutch away from the flywheel. It doesn't matter if it would be slipping when it's touching or not, because it's not touching.mesaboogie18 wrote:The reason it won't shift is b/c the clutch is slipping and not fully disengaging fast enough.
2004 VW GTI 1.8T
- Bawked
do a clutch burnout and get holes ripped into your flywheel from the clutch rivets. its the cheap way to get a lightened flywheel
<3 fwd
When you step on the clutch pedal, it doesn't actually move the clutch disc. It unclamps the pressure plate, so that the clutch disc is no longer clamped tightly between the flywheel and the pressure plate. Now if the transmission input shaft splines are rusty, or the clutch disc hub is deformed, the clutch disc can remain stuck up against the flywheel and still be capable of transmitting torque even though it's not being clamped by the pressure plate.LHOswald wrote:i think i brought this up before but i can't find it. oh well.theholycow wrote:That part doesn't make sense. When you step on the pedal, it pulls the clutch away from the flywheel. It doesn't matter if it would be slipping when it's touching or not, because it's not touching.mesaboogie18 wrote:The reason it won't shift is b/c the clutch is slipping and not fully disengaging fast enough.
I am 12 and holy shit what the f**k happened in this thread?
You didn't the whole post?94Corolla5Speed wrote:At first I didn't your original post because you said it stayed at 4000 RPM yet accelerated. I figured the electricals screwed up and weren't displaying proper RPM. After reading more though, I'd say go get a new clutch and resurface or get a new flywheel.
- mesaboogie18
This thread started off good but became epic fail pretty quick.Leedeth wrote:I am 12 and holy shit what the f**k happened in this thread?
Point is, it was the clutch all along (not me beating on the car or my horrible shifting skills) and I'm ordering up an upgraded setup soon. Until then, I'm driving the car like a granny and it sucks! Having torque out the @$$ available right by my feet and not being able to floor it...it's torture I tell you.
2004 VW GTI 1.8T
Now THAT right there is the kind of expertise that this thread needed!Rope-Pusher wrote:When you step on the clutch pedal, it doesn't actually move the clutch disc. It unclamps the pressure plate, so that the clutch disc is no longer clamped tightly between the flywheel and the pressure plate. Now if the transmission input shaft splines are rusty, or the clutch disc hub is deformed, the clutch disc can remain stuck up against the flywheel and still be capable of transmitting torque even though it's not being clamped by the pressure plate.
I've seen that a couple times lately, I think...what's up with that? Some meme I missed?Leedeth wrote:I am 12 and holy shit what the f**k happened in this thread?
