New noise from engine
What is that sound? It comes from the engine, follows the engine RPM, comes and goes randomly. It started yesterday after an hour of smooth driving and would go away if I put it in neutral and let it get down to idle. This morning in the cold it did made the noise a lot until it warmed up. It sounds a little rougher in person, but not quite like a plastic gear grinding. Stereo is off and it's definitely not coming from the speakers.
Shorter video where it was recorded better:
Longer video where you can hear the way it follows engine RPM:
mtheis
Cars: 07 Corolla, 76 Celica
Re: New noise from engine
Post by mtheis »
Well, I'd guess that you either recently installed a turbine engine or you have issues with your alternator.
2007 Corolla
2017 Cannondale Quick 3
1995 Tercel
1976 Celica GT
Unofficial SS.com IRC Server
Official lurker
I'd love if it turns out to just be the alternator.
On another forum I got these suggestions: serpentine belt, idler, power steering fluid, belt tension or noise from tensioner itself.
I would LOVE for it to be any of these things. Easy and cheap FTW. Especially if it turns out to be maintenance that I should have done anyway!
Post by IMBoring25 »
Anything plugged into the power point?
I've got a million electric accessories, but I don't think any were receiving power at that time. If I found something that was, how could it have been involved?
theholycow wrote:I'd love if it turns out to just be the alternator.
Sounz like belt tummy. pop it off and run w/o the belt to verify? Also, when belt is off, czech pulley surfaces for knickz or chipz, check tensioners/idlers for smooth rotation, spin alternator & PS pump by hand.
Goodyear makes a gatorback belt that took care of belt noise on my daughter's cavalier. I still had to replace her idler and tensioner pulleys to get rid of the squeaking. You could feel a roughness when rotating the pulleys by hand - seals had let water in and the bearings were rusted.
Good ideas.
The Gatorback is highly recommended in the truck forum.
LHOswald
Cars: '99 Civic Hatch w/B16a
Post by LHOswald »
i was the first one that posted here but it got deleted :(
i said either something is rubbing or its a belt
Leedeth
Post by Leedeth »
LHOswald wrote:i was the first one that posted here but it got deleted :(
Why the f**k would it get deleted?
There's nothing in the logs.
Its because you suck.
I can also vouch for the Gatorback belts. Only parts store available belts I will run on my cars.
Draklen
Cars: 2010 Hyundai GenCoupe
Post by Draklen »
I believe the car is trying to contact the mothership.
I have no idea.
LHOswald
Post by LHOswald »
Draklen wrote:I believe the car is trying to contact the mothership.
epic
If I don't fix the noise, will I get to fly it into orbit? Cool!
