performance chip
Re: performance chip
T3rb0ez are better
That's right.paul34 wrote:THERE AIN'T NO REPLACEMENT FOR DISPLACEMENT
My speedometer and torque beg to differ
i could put an aftermarket speedometer in my truck that goes to 300 that doesnt make it any faster lol. and you would have way more torque with more displacement. watkins fail!
They will beg for mercy trying to keep up with the goat.watkins wrote:My speedometer and torque beg to differ
It will be interesting. But regardless, you still have more power than I do.
Lets see... I theoretically make about 56hp and 63tq per cylinder. Not too bad for 11 years ago.
- Cars: Stg 3+ Saab 9-3
You are right, except for the fact that the boost threshold is so very low on my car, as it is on many new cars, that closing the wastegate at like 1500rpm is similar to your illustrated case of flooring it when the turbo is capable of max boost. For example, I can modulate boost pressure with throttle, which for the rest of you non Saabers means I can get 10psi @ ~1800 rpm, and 6 or so at 1400-1500rpm. This is not to say I do this, as loading the engine enough to get this boost this low doesnt sit well with me.LHOswald wrote:i was the one who said if the wastegate was shut you wouldn't go faster. but obviously you missed what i said so i guess ill say it again.
if the wastegate is shut (therefore spooling the turbine as fast as possible) at low rpms the boost threshold is pushed farther up the RPM band (because the wastegate is shut) causing you to hit some turbo lag and therefore not move you as fast. im sure if you kept it floored in a high gear after you hit about 2.5k-3k rpms you would notice a considerable boost in acceleration, but lower than 2k and it would be pretty sluggish
-Cm
- eaglecatcher
- Cars: '90 300ZXTT 5MT
I was under the impression that wastegates stayed shut until you reached the desired boost pressure and then opened as necessary in order to maintain that pressure?
Z1 Intake
Z1 2.5" Test pipes
HKS 65mm Hi-Power Exhaust
AMS Short Shifter
SZ Subframe Spacers
HKS Vein Pressure Converter
DDM Tuning 6000k HIDs
Z1 2.5" Test pipes
AMS Short Shifter
SZ Subframe Spacers
manual boost controllers are usually just springs against a wastegate. lets say its tuned for peak boost of 10 psi. theres a spring on the wastegate that has the exact right pressure to keep the turbo at no more than 10 psi no matter how much boost is being thrown through the turbo. electronic boost controllers do the same thing but electronically.eaglecatcher wrote:I was under the impression that wastegates stayed shut until you reached the desired boost pressure and then opened as necessary in order to maintain that pressure?
Actually most MBCs these days are independent spring-valve units that control vacuum. At least for legitimate turbo applications.
shoe polish
Ass. You coming to WV?
im not gonna be able to make it all the way out to west virginia for a meet. way to far and i have zero doll hairs
Even if we pick you up on the way by?
