I have a 95 jetta w\a5 speed linkage probs.
- Cars: 1991 honda civic- 4 speed
95 jetta wont go into reverse gear, shift partially disassembled wont go down and left to get under stop to go forward left and up to engage. All help appreciated.
Re: I have a 95 jetta w\a5 speed linkage probs.
Wait a second. Are you saying that the shifter will not go down and move left at all? Sounds like a linkage issue. What is disassembled exactly?
If the shifter does not go into gear: does it go into gear when the car is stopped with the engine off? If so, you likely have a hydraulic issue.
More details, please.
I was at first having a problem getting it in first gear. At the time I was able to press down to get in to reverse under the track to the left. I was told the problem I was having was I needed to get a repair kit that it was worn and needed to be replaced. Here is a link to what i got:
http://www.pap-parts.com/prodinfo.asp?n ... %20116%20A
I hired a guy to put it in and apparently he had some problems installing it. After he installed the kit the shift stick was very loose and i wasn't able to press down to get in to reverse. I did get into first fine though.
If it's a linkage issue it's hard to really pinpoint and I must be honest - I am not very familiar with it.
- comingbackdown
Dubbers unite. Didn't one of you guys have a Jetta from that generation?
