Shifted into third, clutch not fully in, now problems
quackman
Re: Shifted into third, clutch not fully in, now problems
Post by quackman »
I have no problems other than the stick shaking in 3rd--moreso when i'm accelerating, and when i'm decelerating it's pretty much completely still as in other gears.
As far as what BMW dealer said "i've driven your car and two other M3s and it's normal."
yeah ok. well, it's not popping out of gear or anything like that, and since BMW says it's normal I guess that's that. sigh.
Most RWD/4WD manual transmission vehicles have the stick attached directly to the transmission, unlike FWD/AWD vehicles where it's remotely connected by cable. As such, the stick in a RWD/4WD vehicle moves with the transmission, not with the body.
Is it vibrating, or shaking? Vibrating heavily I'd expect, I'm not so sure about shaking.
Possible a fork got bent and it's not being positioned fully into 3rd gear any more - does 4th seem to be getting fully into gear too soon? Measure travel of neutral gate line on shift knob forward from Neutral into 3rd and backward from Neutral into 4th. Should be nearly the same.
LHOswald
Cars: '99 Civic Hatch w/B16a
Post by LHOswald »
davidmorgan744 wrote:I think the use of clutch must be applied while changing the gears. It works without that also but it will affects the bike. The use of clutch properly makes the bike to work effectively.
uhhh engrish prease?
FDSpirit
Cars: 2000 Honda Civic Si
Post by FDSpirit »
Heads just asploded.
Don't worry, he's a spammer.
When the first sound of the intro to that song came on, I immediately knew what the drum beat was going to be. I've never heard the song nor heard of the singer.
