Squeaky Clutch
Squeaky Clutch
I noticed this about a month ago. When I first start the car, and for the following fifteen minutes or so, the clutch makes a squeaky-hinge noise like you might hear from a worn mattress spring: wreeee. This noise happens only when I kick the clutch pedal down, not when I lift my foot off. At first I thought it was the pedal itself but I ruled out that because the sound is louder when I have the windows down. I asked my mechanic about it possibly being the clutch fluid, which is black, but he said he's been driving a pickup for over a decade and has never changed the clutch fluid in that. I'm out of ideas. I've only been driving a stick for a year and so far I haven't had any problems. I haven't noticed any roughness in shifting and after about fifteen minutes of driving the noise diminishes and the car more or less operates without the sound. But for those fifteen-twenty minutes it sure sounds annoying... Draws looks from pedestrians, too. Any suggestions? Thanks.
Re: Squeaky Clutch
have a friend stomp the pedal and go up under there and see where you can narrow the sound down to. or just replace the clutch. or just get a new car. or just cut off your ears. i think all of those could work
- FDSpirit
- Cars: 2000 Honda Civic Si
Re: Squeaky Clutch
If your clutch fluid is black, you might wanna bleed the system. Black fluid is no bueno.
Re: Squeaky Clutch
Probably a moving part (like the clutch fork, or the clutch disc's interface with the input shaft) that needs some grease.
What kind of vehicle is it? If it has an old-fashioned rod linkage then that may need some grease and is easy to work on.
Re: Squeaky Clutch
If it is an external slave HCRS, it might be the release bearing fork squeaking against its pivot ball. Get your haid right close by the bellhousing whale somebody (with the wheels chocked and the park brake applied) exercises the clutch pedal for ye. Mebbe there is a bellows or a cover you have to remove to see the release fork. Try putting grease onto the pivot stud by using a paintbrush, not a spray nozzle, so you don't get any on the rotating parts. With your fingers and the brush out of the way, have someone exercise the clutch pedal again to work the lube in and see if you got it done or if more is needed. Also, if you can't get it in there (TWSS) between the fork and the top of the pivot, you might want to make like Honest Abe and free the slave, so the fork is unloaded and easier to move around. It's incredible that a guy could be blogging about working on his clutch release system and end up getting into a big war over it. Bet most of you didn't even know Lincoln was Amish. The beard thing makes all kind of sense now, right?
Re: Squeaky Clutch
Depends. The fluid on the goats and G8's gets black within a few hundred miles. It's not been linked with any issues that I know of.FDSpirit wrote:If your clutch fluid is black, you might wanna bleed the system. Black fluid is no bueno.
Re: Squeaky Clutch
Iffen it's yellow, let it mellow.AHTOXA wrote:Depends. The fluid on the goats and G8's gets black within a few hundred miles. It's not been linked with any issues that I know of.FDSpirit wrote:If your clutch fluid is black, you might wanna bleed the system. Black fluid is no bueno.
Iffen it's brown, flush it down!
- FDSpirit
Re: Squeaky Clutch
Didn't know that, Tony. I just figured the same applied to clutch fluid, since it's brake fluid. mine hasn't changed in color since I bled the system. I find that weird though in your case.
Re: Squeaky Clutch
Does this mean that Tony blew a seal? No more trips to the Chicago zoo for you young man!FDSpirit wrote:Didn't know that, Tony. I just figured the same applied to clutch fluid, since it's brake fluid. mine hasn't changed in color since I bled the system. I find that weird though in your case.
Re: Squeaky Clutch
Or SeaWorld.Rope-Pusher wrote:Does this mean that Tony blew a seal? No more trips to the Chicago zoo for you young man!
Re: Squeaky Clutch
OH Man, I hope we're not too late! President ford dies, Squeaky Fromme gets released from prison, and now Rufio275 has a squeaky clutch release system. Coincidence? I hope he calls the secret service and goes into a safe house until they catch that wacko.
And Charles Manson sits in prison and laughs to himself. Lousy Krauts!
Re: Squeaky Clutch
theholycow wrote:Probably a moving part (like the clutch fork, or the clutch disc's interface with the input shaft) that needs some grease.
It's not that old. At least I wouldn't consider it old. It's a 2000 Honda Civic.
So isn't it a little strange that my mechanic said he's never changed the clutch fluid in his truck before? Which means, I'm assuming, that he's never bled the thing either.
- FDSpirit
Re: Squeaky Clutch
Bleeding the system wouldn't hurt. It's actually really easy on your car. I've pretty much got the same car as you do.
Re: Squeaky Clutch
Ah, yer all a bunch of pussies!FDSpirit wrote:Bleeding the system wouldn't hurt. It's actually really easy on your car. I've pretty much got the same car as you do.
(In a falsetto voice) "Oh, I've got to go bleed my clutch today!"
In my day, men never bled their clutch juices and we liked it that way. It was good enough for us. I think Alice Cooper said it best: "Only women bleed".
Signed,
Harry Mechanic
Re: Squeaky Clutch
I've NEBBER had a clutch pedal go down on me, but that's a good thing, right?paul34 wrote:The Corvette guys sorta freak out over black clutch fluid because they say it's the cause of a clutch pedal that'll suddenly fail to come back up one day.AHTOXA wrote:Depends. The fluid on the goats and G8's gets black within a few hundred miles. It's not been linked with any issues that I know of.FDSpirit wrote:If your clutch fluid is black, you might wanna bleed the system. Black fluid is no bueno.
