theholycow wrote:Damn you electric educated folks...how are you getting 16.7 ohms out of anything I posted? There's something here for me to learn.
Voltage (V or E, Electromotive Force, in Volts) = Current (I, in Amps) X Resistance (R, in Ohms)
Solve for R --> R = V/I. For a 12 Volt source dissipated to ground (This should be what's going on) at 0.72 A, R = 12 / .72 = 16 2/3 Ohms.
You can also use P = IE to conclude that 8.64 W are being dissipated when the battery is charged to 12 V.
theholycow wrote:As for the shift interlock, that's handled by a solenoid at the shifter inside the vehicle. I had to take apart the entire console area to reach it.
A solenoid is a fairly typical way to actuate the locking-in or locking-out of gears, but it does have to be in a circuit that renders it "sentient" of whether the conditions for the gear to be locked in/out are met or not.
