94Corolla5Speed wrote:94Corolla5Speed wrote:
2. Tried using an A/C recharger with PSI gauge attached. I kept pumping refrigerant in there but the pressure stayed the same (low pressure, would need to add). No visible leaks.
Shadow wrote:The compressor will not engage if your refrigerant is very low/empty. Did you even check that yet?
I meant with a real gauge. Those Mickey Mouse gauges that come on the bottle of refrigerant you buy in Wally World are basically worthless.
