New clutch and flywheel problem
I've recently changed my clutch and flywheel to F1 racing-stage 1 couple of weeks ago. I was teaching my gf stick in an uphill, so she was slipping my clutch a bit. After a while, I took the front wheel and drove home, only to find out that my clutch started slipping while engaged (my RPMs were too high for my actual speed and fluctuates up and down while pressing the gas). So I proceeded to test it on the highway, and it was the same thing. I went home, ate some lunch and let the car cool for awhile, and tested it again. Now it's perfectly fine even with hard accelerations. Now I'm wondering whether its because of the heat causing the clutch to slip, or there's something else wrong, such as the pressure plate, flywheel, etc? Anybody had this experience with a new installed clutch and flywheel?
Re: New clutch and flywheel problem
An over-slipped clutch will glaze. Driving normally wears this glazed layer off and life is back to normal.
MmmmmmmmmmmmmmmmmmmmmmmmmmmmmGlazed!watkins wrote:An over-slipped clutch will glaze. Driving normally wears this glazed layer off and life is back to normal.
I hear that a cup of coffee will speedily help remove the glazing.
That happened to me on my clutch, which is a few months old.
The shifter cable (car is old) might have gotten jammed or displaced while driving over a rough road. My RPMs went way up but the car took forever to engage from neutral to first, and it was semi-normal into 2nd gear. I didn't go past that.
I let it cool off and it shifts normal now, but the clutch feel is not as "heavy" as it used to be
