Light blinking
Light blinking
Postby Squint » Tue Aug 21, 2012 10:25 am
Left turn signal on the civic is acting funny. All the bulbs seem to be functioning, but the timing is off on the light.
If the lights are off, the turn signal blinks super fast like a bulb is out.
If the lights are on, even just running lights, the turn signal blinks at just slightly off normal speed, but it isn't a regular blink. If a regular blink lasts 1/2 second or so, this is lasting roughly a 1/4 second or less. It's more of a quick flash than blink.
Could it be the flasher has a problem and needs to be replaced since it doesn't appear to be bulb related?
Re: Light blinking
Postby theholycow » Tue Aug 21, 2012 10:29 am
It's more likely dirty connections and grounds, but replacing the flasher might be an easier thing to try.
Actually, since it changes based on headlight status, it sounds like a short in a dirty multi-function switch or connector. Does the turn signal stalk control your headlights and/or high beams?
Re: Light blinking
Postby Squint » Tue Aug 21, 2012 10:32 am
theholycow wrote:Actually, since it changes based on headlight status, it sounds like a short in a dirty multi-function switch or connector. Does the turn signal stalk control your headlights and/or high beams?
Yes. Looks like this
Re: Light blinking
Postby Rope-Pusher » Tue Aug 21, 2012 10:42 pm
Half few F-er scene a brakelight filament sag onto the taillight filament? or vice-versa?
Re: Light blinking
Postby Squint » Tue Aug 21, 2012 10:55 pm
Rope-Pusher wrote:Half few F-er scene a brakelight filament sag onto the taillight filament? or vice-versa?
Can't say that I have. Also, I'm glad to have to decipher your posts again. Always wakes up the brain.
Re: Light blinking
Postby Rope-Pusher » Tue Aug 21, 2012 11:09 pm
Whale Eye Half, ant tit ken gift symptoms like hugh R resperiencing. Go look at all your bulbs and compare the brightness left-to-right. Ewe mite sea sum ting enter rest ting.
Re: Light blinking
Postby potownrob » Wed Aug 22, 2012 11:54 am
don't forget to check the blinker fluid level
Re: Light blinking
Postby bk7794 » Thu Aug 23, 2012 4:59 pm
The fluid level helps for me lol kidding.
Have you recently replaced a bulb? Once I installed a single filament bulb into a dual filament socket. Whenever I would step on the brake the horn fuse would blow.
2000 Honda Civic EX 5 Speed
Volvo S60R 6 Speed - Sold
Re: Light blinking
Postby Squint » Fri Aug 24, 2012 12:15 pm
bk7794 wrote:The fluid level helps for me lol kidding.
Not recently. I haven't had a chance to inspect the bulbs yet up close. I'm going to try to do it after work today or tomorrow, but I've been working late so it's harder to see when it's getting dark.
RP, could the filaments be touching just on the left side where the bulbs are acting funny? Or on the right side where everything is working normally?
Re: Light blinking
Postby theholycow » Fri Aug 24, 2012 1:30 pm
Based on the good ideas in this thread, I'd say the first order of business (besides visually inspecting the bulbs) is to swap the bulbs left-right and see if the symptom follows.
Re: Light blinking
Postby bk7794 » Fri Aug 24, 2012 4:42 pm
Also when inspecting them I always put the hazards on. This how I know which bulbs that are supposed to blink
Re: Light blinking
Postby Rope-Pusher » Sat Aug 25, 2012 3:30 pm
bk7794 wrote:Also when inspecting them I always put the hazards on. This how I know which bulbs that are supposed to blink
How does that help you determine which bulbs should be blinking?
SonicHKS
Cars: 2012 Chevy Sonic Turbo
Re: Light blinking
Postby SonicHKS » Fri Aug 31, 2012 12:39 am
Sounds like a bulb is out, or a bad ground. Best I can say for grounds is find them and clean them with a wire brush.
Bulb, it could be just about anything. Pretty much every light is dual-filament and if even 1 filament goes out it can cause a short. It depends on car, but on some cars none of the lights even change, you'd have to turn on your p/l, turn signals, emergency flashers, headlight lo-beams and high-beams, etc and see if a stage on one of the bulbs doesn't light up. I'd also inspect sockets if you can, make sure the bulbs are able to ground out.
One thing that can complicate it, on some cars a lot of other things are on the same circuit, like horns, etc. You might need a multimeter to check it all out.
I had a problem like this on the Fiero last year. Was in an accident and got a new front end welded on, ended up using a j/y front wiring harness. I had to replace a horn, fix 2 sockets, and replace all the bulbs before it all worked right.
Re: Light blinking
Postby Squint » Fri Aug 31, 2012 12:00 pm
Looks like front drivers light has some corrosion/something on the back of the light mount. I'm going to clean it off and see if that helps at all.
