Page 1 of 2
I think my clutch is slipping
Posted: Sun Aug 26, 2012 9:00 pm
by bk7794
So another problem..
The other day I was in 4th gear driving up a slightly uphill on ramp. The engine rpm went up a bit but the speed didn't increase. Now it only happens in 4th gear and only sometimes. However I get this vibration when I give it a good amount of power in 3rd, 4th, and 5th gear, I am betting this all could be related.
Also there was only 70k on this clutch. I was wondering if the cheap aftermarket part had something to do with this.
Re: I think my clutch is slipping
Posted: Mon Aug 27, 2012 12:15 am
by Shadow
Hmm...maybe your clutch is slipping. One way to tell if your clutch is slipping is to put the car in 4th or 5th gear at a dead stop with the parking brake on and engage the clutch. If the car doesn't stall immediately, it's a good indication that your clutch is slipping.
Posted: Mon Aug 27, 2012 6:49 pm
by bk7794
Shadow wrote:Hmm...maybe your clutch is slipping. One way to tell if your clutch is slipping is to put the car in 4th or 5th gear at a dead stop with the parking brake on and engage the clutch. If the car doesn't stall immediately, it's a good indication that your clutch is slipping.
Alright I will have to try that. It probably will stall because its on the beginning of the way out.
Posted: Mon Aug 27, 2012 8:59 pm
by AHTOXA
What he's doing also works to diagnose most clutch slippage. Select gear closes to 1:1 ratio (usually 4th) and floor the throttle in the beginning of the power band of the car while driving. Speed will vary based on the powerband. A slipping clutch will often show itself then.
Posted: Mon Aug 27, 2012 9:14 pm
by bk7794
AHTOXA wrote:What he's doing also works to diagnose most clutch slippage. Select gear closes to 1:1 ratio (usually 4th) and floor the throttle in the beginning of the power band of the car while driving. Speed will vary based on the powerband. A slipping clutch will often show itself then.
Yup in 4th gear it slips going on the on ramp and usually uphills...ugh it only lasted 70k..
Posted: Sat Sep 15, 2012 8:31 pm
by comawhite
bk7794 wrote:AHTOXA wrote:What he's doing also works to diagnose most clutch slippage. Select gear closes to 1:1 ratio (usually 4th) and floor the throttle in the beginning of the power band of the car while driving. Speed will vary based on the powerband. A slipping clutch will often show itself then.
Quit vtecing xP
Posted: Sat Sep 15, 2012 9:19 pm
Found the problem...
Posted: Sat Sep 15, 2012 9:30 pm
Posted: Sun Sep 16, 2012 1:13 am
by potownrob
Posted: Sun Sep 16, 2012 3:44 am
by six
What happened?!
Posted: Sun Sep 16, 2012 7:21 am
Posted: Tue Sep 18, 2012 3:55 pm
by bk7794
I wonder what the clutch will look like when I eventually do it. I wonder what its going to feel like after I replace it with an OE clutch. So excited, now I need to find the time.
Posted: Wed Sep 19, 2012 1:42 am
by potownrob
Posted: Wed Sep 19, 2012 9:20 am
by Shadow
That reminded me of this:
Posted: Thu Sep 20, 2012 2:00 am
by comawhite
bk7794 wrote:I wonder what the clutch will look like when I eventually do it. I wonder what its going to feel like after I replace it with an OE clutch. So excited, now I need to find the time.
I wonder, what mine looks like too. Same with the flywheel.
I bet it looks like crap due to a rear main seal leaking. Plus, I get to see what damage I did to it when I was learning how to drive manual with it (even though it was slipping a little when I bought it.) 110,735 miles with factory clutch is not bad.
What did do to cause a burning clutch for a burnout? Weren't they suppose to drop the clutch at a high rev and then hit the brakes quickly while giving it gas? Or at least that is what I've been told (don't have RWD manual only automatic and scared to do it in an automatic).
