Car doesn't start!
Car doesn't start!
Postby bk7794 » Sun Nov 11, 2012 1:12 am
Well today I got up for work and went to my car. I go to start it and it cranks...and cranks...and cranks. I found that the main relay works because I hear it click and the igniter unit is good, because I had two. I have no CELs. The car was running like a champ last night. :(
2000 Honda Civic EX 5 Speed
Volvo S60R 6 Speed
Re: Car doesn't start!
Postby Shadow » Sun Nov 11, 2012 1:18 am
Go back to basics. Make sure the engine has spark & fuel. Those are the very first things to check.
Postby bk7794 » Sun Nov 11, 2012 1:26 am
It's got spark. I am guessing it isn't getting fuel. I will have to check the Throttle body Tomorrow.
Volvo S60R 6 Speed
Postby Shadow » Sun Nov 11, 2012 1:38 am
Can you hear the fuel pump energizing when you first turn the key?
Postby bk7794 » Sun Nov 11, 2012 1:41 am
Shadow wrote:Can you hear the fuel pump energizing when you first turn the key?
Yes. Also compression sounds good aswell.
Volvo S60R 6 Speed
Cars: '16 Golf TSI SE
Postby potownrob » Sun Nov 11, 2012 9:58 am
bk7794 wrote:It's got spark.
Postby bk7794 » Sun Nov 11, 2012 11:53 am
Thats a decent looking car.
So today because its a throttle bodied engine I decided to throw some raw gas into the throttle. It didn't work.
Volvo S60R 6 Speed
Postby Rope-Pusher » Sun Nov 11, 2012 12:40 pm
pull a plug and Czech to see F N it's wet.
Is there a place to vent the fuel line up near the injectors? Vent the pressure and then see F N it pressurizes again with the negst attempted start.
Postby bk7794 » Sun Nov 11, 2012 12:49 pm
Rope-Pusher wrote:pull a plug and Czech to see F N it's wet.
It was dry, but it smelled of gas. Also the injectors do spray fuel.
EDIT The plugs were wet. Also I am getting a brownish spark. I am wondering about this coil though, it says in the book it should be 9.XXX to 14.XXXX. Now I don't know if thats 9000 to 14000 ohms or just 9.000 to just 14.000 ohms.
Volvo S60R 6 Speed
Postby bk7794 » Mon Nov 12, 2012 3:48 pm
Car started right up. Bad coil.
Volvo S60R 6 Speed
Postby Squint » Mon Nov 12, 2012 5:19 pm
bk7794 wrote:Car started right up. Bad coil.
Solved, woo!! Manage to still get to work with a non-functioning car?
Postby bk7794 » Mon Nov 12, 2012 8:47 pm
I got to use my dads car. 01 Taurus slushbox. I tell you the thing rides like a dream...but does not take bumps well.
It felt good to get back behind the wheel of the civic. I tell you nothing like pulling in a gear and shifting whenever I want.
Volvo S60R 6 Speed
Postby Squint » Tue Nov 13, 2012 1:17 pm
bk7794 wrote:It felt good to get back behind the wheel of the civic. I tell you nothing like pulling in a gear and shifting whenever I want.
Drove a couple year old Mazda 3 last night at work. It was an auto, but showed you the gear it was in on a display on the dash, like if you were driving a manual and it had electronic HUD. I was very confused at first.
Postby bk7794 » Tue Nov 13, 2012 4:01 pm
It had paddle shifters? Those seem nice.
Volvo S60R 6 Speed
Postby Squint » Wed Nov 14, 2012 10:39 pm
Nope, no paddle shifters. Just the shifter where instead of 2nd and "low" is has +/- and you can shift through all the gears by going up and down. Kind of like a driving arcade game. Though I have driven several cars that do. Unless I were really racing, I think I just ignore them for the most part. The Camry SE has them, but it won't let you blow anything up by being in the wrong gear, so it can be set in 4th from a stop and it will automatically switch to 1st for you. The lazy side of me lets it take over.
