Escort problems, pic
wannabe
Cars: NONE - take the bus
Postby wannabe » Tue Mar 11, 2014 4:03 pm
Fix (have friends do it, not this shop), or drive till dead, or sell for scrap?
(Note: I have no money for a new car, however I do have funds for repairs.)
Crafting and stuff
Re: Escort problems, pic
Postby theholycow » Tue Mar 11, 2014 4:10 pm
Sway bar links are not a catastrophic failure. New ones will help the car handle like it should and be more stable. If you shop online you might get them for $10. They're very easy to install.
Struts, depends on what's wrong with them. They're structurally important so if they're really broken then the car won't be safe or probably driveable at all. If they're just basically worn then handling could be sloppy. I'm going to guess that they were recommended because the shock absorber function was worn out; if so then it's no worse than driving a vehicle with worn shock absorbers. They're probably quite expensive
Radio is obviously entirely your choice.
IAC motor cleaning: Do you have any symptoms? Unstable, unpredictable, or wrong RPM (especially at idle)?
Postby tankinbeans » Tue Mar 11, 2014 4:17 pm
If you have the money for repairs you'd be served well to fix these things. They don't seem too scary to me. Work your way down the list from most pressing to least pressing.
The radio is a no-brainer. Buy an aftermarket unit and have a friend, or you (if you're so inclined), install it. It shouldn't be too difficult nor expensive.
Postby Squint » Tue Mar 11, 2014 4:41 pm
tankinbeans wrote:The radio is a no-brainer. Buy an aftermarket unit and have a friend, or you (if you're so inclined), install it. It shouldn't be too difficult nor expensive.
Especially if you can buy it used from someone - seriously cheap that way.
However, that should be lower on the list than all the rest of the car repairs.
Postby AHTOXA » Tue Mar 11, 2014 4:50 pm
Unless your swaybar links are broken and dangling, I'd leave them for last.
I'd probably replace struts as the priority item if you were going to keep the car for a while. Depending on how badly they are worn, they can be dangerous and costly in the long run. If they are worn so badly that the car continues to bounce down the road after hitting a decent bump, they need replaced. When it's that bad, the tire can be bouncing quite a bit, while the whole car itself feels very floaty. This results in far greater stopping distances, particularly over bumpy road, because the tire isn't in constant contact with the ground as it's designed to be. Also, your tire is at risk of increased wear - uneven wear - as the shocks are no longer doing their function.
So if I had to keep the car on the road, I'd do the struts first, barring any other severe issues and go from there.
Postby tankinbeans » Tue Mar 11, 2014 5:06 pm
I meant to imply that, but didn't communicate the implication clearly.
Postby theholycow » Tue Mar 11, 2014 5:44 pm
Honestly, I've had good results with ultra-cheap off-brand radios that promise a ton of features. They're not audiophile quality nor can they drive huge subs without an amp, but they tend to sound as good as a mid-level OEM stereo from the 2000's. I suspect that a $25 Walmart radio would be decent enough (and easy to return if not!).
AHTOXA wrote:Unless your swaybar links are broken and dangling, I'd leave them for last.
My theory is that they are not broken but are rusted enough that the shop knew they'd break while trying to take stuff apart to replace the struts.
That's another thing...the strut job is probably going to reveal a few seized parts that will break during the job.
Postby watkins » Wed Mar 12, 2014 8:54 am
Old car suspension is the devil.
Postby theholycow » Wed Mar 12, 2014 9:41 am
watkins wrote:Old car suspension is the devil.
How about 34 year old, 100,000 mile old-school domestic boat suspension? :lol:
Actually I think my front shock absorbers might have been replaced at some point, and I replaced the rears last year. Also did front wheel bearings. Might do some preventative front end work this summer but it's not looking too likely.
wannabe
Postby wannabe » Thu Mar 13, 2014 3:25 am
shop said the front sway bar links are broken, back are loose.
Struts you can hear when the car is turning, they're shot and need to be fully replaced.
I think my uncle did my rear ones, he'd probably do my fronts as well.
only thing on the rradio is that it don't light up. i know what stations my presets are, this is really no big deal. and i know the local stations well enough that i can find them again if the battery were to be replaced.
(all of GR, MI is bumpy road. in some places theres no smooth spot to drive on (in either lane!) to get across a spot....)
Crafting and stuff
wannabe
Postby wannabe » Thu Mar 13, 2014 4:32 am
re: the radio. idk if you've seen an escort (or tracer) radio, but its a radio/climate control all-in-one dealie. weird. idk. i don' tmind it, i'd just like my clock to work. but thats what celll phones are for!
Crafting and stuff
Postby tankinbeans » Thu Mar 13, 2014 7:52 am
There are probably plenty of 96-02 Escorts/Tracers in the junkyard and you should be able to find a cheap stock unit.
Postby theholycow » Thu Mar 13, 2014 10:16 am
wannabe wrote:re: the radio. idk if you've seen an escort (or tracer) radio, but its a radio/climate control all-in-one dealie. weird. idk. i don' tmind it, i'd just like my clock to work. but thats what celll phones are for!
Like this?
It's still a separate unit, but it does have that integrated faceplate...a non-stock radio would require ugly hacking but is probably still possible, assuming there's sufficient space for it. Otherwise you could end up mounting an aftermarket radio on a bracket somewhere else.
Anyway, I agree with tankinbeans, at that point if you must replace it then get a stock one at a junkyard.
You could get an aftermarket clock and stick it to the dash. They're like $5 in the car bling aisle at Walmart, next to the ricey pedal covers, shift knobs, and window tint.
Postby tankinbeans » Thu Mar 13, 2014 11:29 am
You elitest. Showing an Escort of that vintage with a CASSETTE deck. How dare you!?
My dad's 99 didn't have one of those! :wink:
InlinePaul
Cars: 2001 S10 2.0L manual
Postby InlinePaul » Thu Mar 13, 2014 12:05 pm
tankinbeans wrote:You elitest. Showing an Escort of that vintage with a CASSETTE deck. How dare you!?
Hey, but for the color that Escort looks just like the one I have at my house (notice I didn't say own, not with that funky lever in the middle) even down to the cassette deck. :lol:
