I've only owned one car in my life that was capable of starting without the clutch disengaged.Reverence wrote:cough## ever started a car in 1st without clutching in?? cough##
Parking brake reminder / warning
Re: Parking brake reminder / warning
I did that once in an old civic. Started in gear with clutch up. Oops.
You don't need to clutch in to move the shifter if the engine is off?Shadow wrote:After the engine is off, I'll usually just pop the shift lever into gear without stepping on the clutch.
2001 Honda Accord
- Cars: 04 xB
Generally not. However the gears may not be in aligned so you cannot always shift into the gear you want. Just don't force it in if it doesn't want to go in
Nope. The shifter will slip into gear without using the clutch.shiftmate wrote:You don't need to clutch in to move the shifter if the engine is off?Shadow wrote:After the engine is off, I'll usually just pop the shift lever into gear without stepping on the clutch.
- Cars: Peugeot 307 2L
I know most cars are build with this kind of protection nowadays. Some aren't, my Peugeot isn't.Shadow wrote:I've only owned one car in my life that was capable of starting without the clutch disengaged.Reverence wrote:cough## ever started a car in 1st without clutching in?? cough##
What happens when you do start in 1st without clutching in is: The car jerks forward by itself for 2-4 meters, depending on how much torque you got. Could be even more dangerous than what could occur when not parking in gear.
- Tups
Cranking on 1st is what you're supposed to do when your car dies in the middle of a railroad crossing...
2007 Ford Focus ST225
1982 Ford Escort Mk3
I usually roll into my parking spots in 2nd, it's really good at creeping, and then pull up on the parking brake. Once fully stopped with the parking brake engaged I'll either go into 1st or reverse, depending on which direction I'll want to go.
The other day, though, I took my mom for a very brief lesson; she wants to learn how to move my car out of the driveway in case I ever leave it by mistake and go out with friends. Long story short I left the parking brake fully engaged when I reversed out of the driveway. There were noises and goofiness, but I didn't think anything of it. Then I look down and saw the warning light and the lever. I felt like a dolt.
Its strange that my car (91) has a clutch interlock switch, and some guy working on an integra (92) and it didn't have the interlock switch...AHTOXA wrote:I did that once in an old civic. Started in gear with clutch up. Oops.
- Cars: 95 VW Golf
95 Golf here without a clutch interlock. I think they went all the way up until 1998 till the 4th generation came out to put a clutch interlock in.bk7794 wrote:Its strange that my car (91) has a clutch interlock switch, and some guy working on an integra (92) and it didn't have the interlock switch...
95 VR6 Golf Sport
I've had a few of those, but they've usually had a weird shift pattern. PRND321.Shadow wrote:I've only owned one car in my life that was capable of starting without the clutch disengaged.Reverence wrote:cough## ever started a car in 1st without clutching in?? cough##
That's strange, the ones that I have seen were labeled PRND32L. You have such strange vehicles there...tankinbeans wrote:I've had a few of those, but they've usually had a weird shift pattern. PRND321.Shadow wrote:I've only owned one car in my life that was capable of starting without the clutch disengaged.Reverence wrote:cough## ever started a car in 1st without clutching in?? cough##
One of the cars that I have driven goes PRNDD1 The first D is small with a circle around it, so its overdrive..but at first I was confused hahaSquint wrote: That's strange, the ones that I have seen were labeled PRND32L. You have such strange vehicles there...
With the exception of one, I've always owned manual transmission vehicles, and I always leave it in 1st when parked and apply the parking brake...just force of habit, even on level ground.
With one car I owned ('91 MR2 Turbo), the E-brake would always get stuck when temps dropped below 20 F...so I always had to remember during the winter to try to park as level as possible and not engage the e-brake.
If you're on a hill, here's my routine: put vehicle in position, turn front wheels, apply parking brake (let off standard brake and allow car to "settle")...reapply standard brake, put car in gear, shut off motor.
Every other vehicle I've owned has been a Toyota truck, and they can start without the clutch depressed, but only if you press a button to allow it. I tried it once on my '86 pickup, and it definitively gives you quite a jolt...the reason that feature is built in to Toyota trucks is to assist in getting out of "tight situations" off-roading...and I understand why!
