As with any small displacement engine, low end torque is not abundant but I have no issues with no-gas launches. I'm going to try adding throttle a little earlier than I normally would, I really think that's my issue.theholycow wrote:Well, that's for a relatively aggressive launch. For polite launches that won't turn heads (especially that cop sitting in the parking lot nearby), you might want to launch that car near idle RPM (but not no-gas -- more gas and more clutch than a no-gas launch, gives you quicker launch than no-gas without requiring high RPM), which will likely require a paused clutch release. I'm not sure, I know that the 2.0t manages a lot of torque from very low RPM, but I don't know exactly how it compares to the 2.5 NA that I'm used to at idle. Obviously this is as much a personal preference matter as it is anything else, and the best way to know exactly what works for you is to try everything, repeatedly, until you find your favorite.daleadbull wrote:So if you dial in the revs with the clutch in, then smooth non-stop clutch release is the way to go then. That's exactly what I needed to know!
Funny you should ask that, my throttle response got a lot of better after my APR flash. When I was stock, rev matching was very hit or miss.theholycow wrote:Don't be afraid of stalling, it's pretty much harmless. I stalled my 2008 VW about seventy million times before I finally got a handle on that clutch and that drive-by-wire throttle.daleadbull wrote:I'm just so afraid of stalling that I'm scared of letting the clutch out without pause. I just need more practice, now to find a good empty place to practice...
By the way, do you have any comments on your DBW, especially having that stage 1 flash?
