Is it worth souping up an automatic?
I've been perusing http://www.cardomain.com lately, and I've noticed that many of the cars on there, while modified under the hood, around the body, or on the inside, are AUTOMATIC!
So is it worth it to buy/rice/pimp/deck out/soup up an auto? And if so, why?
2007 Mazda3
Mods: 15% tint, Eibach ProKit
2006 Ninja 636
Mods: NOS & sidecar
2006 Ninja 636
Mods: NOS & sidecar
It's a lot less to just sell the car and buy a stick than convert over to a manual from auto. I've heard usually its more than the worth of the car, but if you are that attached to your wheels, well, I can't help ya.ReckLess wrote:you can convert it from auto to manual (is there such a thing? ) (but i'd think you'd be spending more..)
2007 Mazda3
2006 Ninja 636
Mods: NOS & sidecar
2006 Ninja 636
Mods: NOS & sidecar
yup there is!you can convert it from auto to manual (is there such a thing? )
i m no expert in mechanics, but the cost of labour will kill ya...
not to mention about major overhauling, taking the engine out of the car and disconnecting the tranmission from the engine is the least there is to it... ECU has to be reprogramed to MT specs, probably valve timing has to be adjusted as well
but y bother w/ this when u can get a better deal on a new car?
IMO i think ppl soup up there automatics r usually for looks and performance w/o the fun of shifting yourself
sorry for sidetracking, but I've sometimes wondered whether converting from a 5-speed manual to a 6-speed manual would be as labor and $ intensive as converting from auto to manual. Any idea???
As to whether it makes sense to rice an automatic, I wouldn't do it but it seems 90% of riced cars in MD are automatic. So, it seems to make sense to some...
If you can't heel-toe, it isn't a car.
Tranny conversions are usually only done by the desperate, such as when the car was never made in stickshift, etc.
For my old car, you could convert to stick for $4000, labor included.
For cars with bigger engines, souping up an automatic will actually get you faster times than a stick. Specially with cars like Camaros and Corvettes, the four gears of the auto are all you need. You simply get higher stall torque converters and different rear end ratios, and you've got yourself a fast, consistent drag car. For the smaller-engined cars, with narrower powerbands, the extra speeds that a stick usually offers provides the gearing advantage, so slushbox versions of those cars are usually slower in an apples-to-apples comparison.
Autos are worth less than sh*t in an autocross, though.
I imagine its not going to be as big of a change as an auto-to-manual conversion, but you're going to need whole different transmission, maybe some reprogramming, and a lot of cash.ltkpn wrote:sorry for sidetracking, but I've sometimes wondered whether converting from a 5-speed manual to a 6-speed manual would be as labor and $ intensive as converting from auto to manual. Any idea???
2007 Mazda3
2006 Ninja 636
Mods: NOS & sidecar
2006 Ninja 636
Mods: NOS & sidecar
There can't be any real guideline for that. It would depend strongly on such factors as:
Is the transmission tunnel big enough for the new transmission? Having to lower the entire driveline in the car (While good for handling), would reduce ground clearance, leave the oil pan more subject to damage, and be very expensive.
Do the hard points match? How far back is the transmission mount from the flywheel face? The shifter linkage? These issues can be worked out, but will increase complication and probably expense.
Finally, how about the total length of the transmission? In most 5-6 speed conversions, I would expect you'd need either to very precisely cut the driveshaft or have a custom one made.
OT: hehehe.. automatics.. they try so hard.. hehehe.. it's for the "old" people..
wow.. that's too much!, the tax here for driving a right hand drive/imported cars is worth the car(100%... WTF...?!) i tell you it's crazy here...Johnf514 wrote:I've heard usually its more than the worth of the carReckLess wrote:you can convert it from auto to manual (is there such a thing? ) (but i'd think you'd be spending more..)
In general, I would have to say no.
However, for the 6th generation Accords, there have been no V6's that came with manual transmissions. That's why I got a 4 banger instead. I preferred having a 150hp car with stick over a 200 hp car with automatic.
I have seen some people swap the auto on the v6's for manual. Expensive, yes....very very expensive.
Good thing some of the newer Accords come with that v6-6 speed, i think it is..
2001 Accord sedan. 5 spd.
- VTECaddict
