...or even in the dark, further up the road?
The Shadow Does!
LEDs FIGHT CO2
Automakers are working feverishly to reduce the CO2 emissions from their cars and even headlamps can play a role. LED lamps use five times less energy than incandescent lamps. By using less electricity that means there is less of a draw on the alternator in a car and that translates into less fuel being used. The French supplier company Valeo says that using LED headlamps can cut 1 gram of CO2 per kilometer. With European regulations set at an average of 95 grams of CO2 per vehicle by 2021, every gram counts. And that’s why we’re going to see LED headlamps to become quite popular with European automakers.
THE “DYNAMIC SHADOW” KNOWS
But there is a big difference how LEDs will be used in Europe and the United States. These lamps are so bright they can blind oncoming drivers. So, starting in 2016 in Europe, they’re going to use what’s called a “dynamic shadow.” Inside the headlamp assembly is a moving shutter that tracks oncoming cars and blocks the light that could blind those drivers. In fact, it will even block out light if its following another car, because the bright LEDs can cause the leading car to cast a shadow in front of itself, making it hard for the driver to see. Valeo says the next generation of LED headlamps will create a “dynamic shadow” by shutting off individual LEDs and getting rid of the mechanical shutter. It’s very impressive technology, but it’s illegal in the U.S. market That’s because the National Highway Traffic Safety Administration has yet to determine if this approach is safe. We say don’t hold your breath for a quick resolution. Back in the 1970s it took NHTSA years of study to determine if it was safe for automakers to change from round headlamps to square ones.
Who knows what evil lurks in the hearts of men?
Re: Who knows what evil lurks in the hearts of men?
As someone who wasn't alive in the 1970s, did they really take years to decide about square headlights? I grew up seeing cars from the 80s and 90s, so square headlights were all I saw
I have experienced this quite a lot when in front of late model vehicles equipped with Retina Burner 9000 (TM) headlights, though I can't say it caused any difficulty. However the usual glare complaints, seeing it in my mirrors or oncoming, remain a problem and are only getting worse.Rope-Pusher wrote:In fact, it will even block out light if its following another car, because the bright LEDs can cause the leading car to cast a shadow in front of itself, making it hard for the driver to see.
I can participate in the lighting arms race ok, upgrading my lighting until it lights the road like everyone else's so that when I become dazzled I can still see, but that still leaves everybody with their pupils contracted, night vision reduced, and phosphenes blocking whatever night vision remains. Mutually Assured Devisionizing...
Too bad the NHTSA won't allow the new technology provisionally as a better than nothing attempt while they take their time researching. We'll all be blind and dead in crashes, but at least they won't incorrectly approve the technology!
If someone has their retina burner leds up close in my mirror, I slow down until they pass. I really have no choice because their lights are so bright that I can't see to merge into the next lane, and I am forced to slow down for safety.
Part of the reason for staying with round headlights was for interchangeability and availability. You could go to any gas station in the middle of nowhere and get an inexpensive replacement headlight if yours was broken or burnt out. They only had to carry 6 part numbers - 3 for 12-volt and 3 for 6-volt.Squint wrote:As someone who wasn't alive in the 1970s, did they really take years to decide about square headlights? I grew up seeing cars from the 80s and 90s, so square headlights were all I saw
One of the reasons the auto companies gave for wanting rectangular headlamps was that their use would allow lower hoodlines, for aerodynamic improvements. Then, when given permission, a popular usage was stacked rectangular bulbs, which did NOT help reduce hoodline height.
Speaking of Volts, when I worked for the army, they discovered that high-voltage incandescent lamp filaments broke more easily when driving over rough terrain. They made adapters for trailers that stepped the voltage down to 12 volts (military often uses 24-volt electrical systems). I wonder if anyone noticed a decrease in bulb longevity when civilian vehicles switched from 6-Volt to 12-Volt systems.
