No physical linkage between shifter and transmission???
Could that ever actually happen? We will someday see a manual transmission that has no physical linkage between the shifter and the transmission? I think we might have touched upon this subject at some point in the past, but now I came across this information from a Car and Driver blog site:
The Missing Linkage
Company: BMW
Official USPTO Name: Vehicle having a transmission and a selection element for shifting gears
What It’ll Do: Replace the physical connection between a manual shifter and a transmission with actuators that mimic the feeling of a physical connection. It sounds crazy, but BMW says it could be used on manuals with as many as eight gears to keep the shift pattern compact. The computer also could lock out certain gates, preventing a driver who’s lost in such a large pattern from grabbing the wrong gear. The system could readily be applied to automatics, too.
Reality Check: Bet on it. With Nissan and Porsche offering automated rev-matched downshifts—and the latter with a seven-speed manual—our favorite transmission type is in a rare era of innovation. Besides, BMW has shown an unending desire to toy with everything on the center console.
Status: Filed in 2012; patent pending.
http://blog.caranddriver.com/the-da-vin ... ture-tech/
The Missing Linkage
Company: BMW
Re: No physical linkage between shifter and transmission???
So...we'll have drive by wire, steer by wire, now shift by wire. I don't see what could possibly go wrong there.
Should be shot down for obviousness and prior art but probably won't be because nothing is...
From the department of redundancy department, when Toyota was having their issues with unintended acceleration, I was reminded of how reassuring it is that manuals have at least two ways to remove power from the drive wheels that are completely independent from any other systems or computers. Scratch one off the list, I guess.
- Cars: 2009 Mazda 5 2.3L 5MT
No thank you! If that happens, I'll be buying older restored vehicles for sure.
11 Subaru Forester auto 113k
The manual gearbox was essentially perfected when syncronizers were added. Anything beyond that is the result of either engineers with too much time on their hands or, more likely than not, engineers being pushed by marketing folks to "improve" an already proved design because marketing folks always have to have something "new" to satisfy the fickle masses.
How about the digital shift knobs that are in the aftermarket? It displays the gear you are in on the top of the knob--like you should be looking at the shift knob while wheeling down the road at 40 or 50 mph!
Chrysler is using automatics with no physical connection already. The auto in the Dart is an actual automated manual. The technology pretty much already exists.
- six
- Cars: 2015 Chevrolet SS 6MT
Don't forget, for a time, Mercedes Benz had brake-by-wire as well.tankinbeans wrote:So...we'll have drive by wire, steer by wire, now shift by wire. I don't see what could possibly go wrong there.
I just have one reminder: SkyNet. It's inevitable. A remote signal can now even shift my manual car?!?!? Doomsday is upon us.
What till they drive though a HERF gun's range! It's one thing to have the car die, but another if it dies and cannot steer! Of course I have never run across an active HERF gun before, or maybe that was why my old 1984 F150 was dying so much, then would start fine after being towed to the shop.tankinbeans wrote:So...we'll have drive by wire, steer by wire, now shift by wire. I don't see what could possibly go wrong there.
My car has a display in the instrument cluster that shows the driver which gear is engaged. It can be turn on & off though...InlinePaul wrote:
Not just Chrysler....lots of newer cars don't have any physical connection between the gear selector and their automatic transmissions. MB has been doing that for years. But for obvious reasons, a manual transmission without a physical connection is a different animal. Of course it can be done, but it will most defintely add significant complexity and cost to what is otherwise a simple transmission.watkins wrote:Chrysler is using automatics with no physical connection already. The auto in the Dart is an actual automated manual. The technology pretty much already exists.
Take the dual dry clutch auto (the automated manual) in the Dart. Add a shift gate with sensors. Add a clutch pedal instead of a hydraulic pump. Done.
Hell, Saab dabbled in alternative manuals back in the early '90s. The Sensonic transmission was a manual with an electronically controled clutch. http://en.wikipedia.org/wiki/Saab_900#Sensonic
Apples and oranges. You're talking about modifying an automated manual, which is already basically a manual transmission that can shift on its own. And IMO, that really makes it an automatic, regardless whether it is based on a manual transmission design or not. If it can shift by itself, it simply ain't a true manual transmission.watkins wrote:Take the dual dry clutch auto (the automated manual) in the Dart. Add a shift gate with sensors. Add a clutch pedal instead of a hydraulic pump. Done.
BTW, look at the smart car---it has been using an automated manual (Borg Warner, if I'm not mistaken) for many years now. Yes, it has an automated clutch instead of a clutch pedal.
Its not apples and oranges at all. Take an automated manual. Add an electronic shifter. Thats only a step away from automating a manual, then adding an electronic shifter. The end result is a "manual" transmission complete with toothed gears and a shift gate.
EDIT:
I just realized you may have meant between the Sensonic transmission and the concept of non-linked shifters and transmissions. That was just a tangent as commentary that engineers have been playing with manuals in odd ways.
EDIT:
So then there is no advantage in having the selector lever on the floor taking up space. They should put it back on the steering column where it is out of the way, or better yet, go like my 1963 Dodge Dart had with the push buttons selectors on the dash board. But many think their car is cooler and/or faster with a big fancy knob on the floor? It sells.Shadow wrote:....lots of newer cars don't have any physical connection between the gear selector and their automatic transmissions.
My dad used to drool about cars with the push button trannies. Could always put them on the steering wheel, I already have 18-21 buttons on my wheel, depending on how you count them.InlinePaul wrote:So then there is no advantage in having the selector lever on the floor taking up space. They should put it back on the steering column where it is out of the way, or better yet, go like my 1963 Dodge Dart had with the push buttons selectors on the dash board. But many think their car is cooler and/or faster with a big fancy knob on the floor? It sells.Shadow wrote:....lots of newer cars don't have any physical connection between the gear selector and their automatic transmissions.
Only half joking.
