Preparing to stop and accelerate
Hello everyone!
I got a question to see if I'm hurting my transmission.
When slowing down to a stop sign for instance I would stay in gear without down shifting. Once my rpms is too low I will clutch in move push on knob into first. I don't force it in but i just keep constant pressure until it slips right into 1st. Now is it bad that im doing this? Or should i just put it into neutral and wait till I come to a complete stop before I put it into first. I'm afraid I might be wearing the 1st gear synchros
06 M Roadster
- Cars: Peugeot 307 2L
Re: Preparing to stop and accelerate
You can stay in whatever gear you're in while braking to a stop, and clutch in to neutral at the very very very last moment just before car stops (later than most people think / do).
It is indeed damaging to your 1st synchros if you shift to 1st before car has stopped, and there really is no point in doing so unless you really must/want to accelerate hard straight away.
Im not forcing it into 1st gear tho when coming to a stop. I just put pressure on it until it slides into gear while slowing down to the stop sign. So would you suggest that I should go to a complete stop or be really really slow before i start trying to put it into first?
06 M Roadster
- Tups
I often shift to 1st in that way, although I don't really have to apply hardly any pressure.
2007 Ford Focus ST225
1982 Ford Escort Mk3
Asking for 1st gear while still at speed is asking the 1st gear synchronizer to do its job when it shouldn't be doing its job. I don't know if I'd call it "damaging" but I'd definitely describe it as too much wear. I don't have enough experience to say that from an expert point of view.
My wife does it and I hate it.
Don't be afraid of neutral, it won't hurt you. Take your current gear down to idle then coast to a stop in neutral; wait until you're stopped or almost stopped to engage 1st.
If you're scared of neutral, then you're left with two options:
1. Add another gear to your downshift pattern. Shift to 2nd instead of 1st, then shift to 1st when you've stopped. This will at least spread the wear out.
2. Double-clutch into 1st, but don't engage the clutch until you're stopped. If you do it perfectly every time then wear will be minimal.
As a side note, my Buick's misbehaving carburetor makes it idle very fast and after neutral-coasting while braking I have to shift into 1st at 10-15mph if I want to avoid excessive synchro wear (and get into 1st quickly)...
You have a really nice car. Clutch out in neutral first before going into 1st gear. It will save you quite a bit of wear. Sure, your car is modern with a well-built gearbox, but still, why put extra wear on it when you don't have to? Don't go straight to first, go to neutral before doing so.
When guys say to go into neutral first would I have to blip the throttle a bit before I put it into first or is it good enough if I put it into neutral and just clutch in again to put it into first?
Sorry for all these dumb questions. This is my first standard car and I learned how to drive it when I picked it up.
06 M Roadster
If you want to put it in 1st while you're still rolling then you'll need to blip while in neutral; then you've double-clutched. If you will wait until the vehicle is stopped before putting it in 1st then there's no need to blip.
I only know of one guy who does this and you know him too.theholycow wrote:If you want to put it in 1st while you're still rolling then you'll need to blip while in neutral; then you've double-clutched.
I think we have a couple folks on here who do that, actually.
I forgot, I can just step on the clutch a few seconds early and let it spin down on its own, or use another gear's synchro as a clutch brake...theholycow wrote:As a side note, my Buick's misbehaving carburetor makes it idle very fast and after neutral-coasting while braking I have to shift into 1st at 10-15mph if I want to avoid excessive synchro wear (and get into 1st quickly)...
I tried this the other day and it work well for me.theholycow wrote:If you want to put it in 1st while you're still rolling then you'll need to blip while in neutral; then you've double-clutched. If you will wait until the vehicle is stopped before putting it in 1st then there's no need to blip.
BMW 328i e90
____________
____________
If I want to go immediately after stopping, I've been known to DCHT into first while slowing for the stop sign. Any other case, and I just wait until going less than walking speed before starting to push the shifter into the gate. Applying pressure into the first-gear gate at road speed without a double-clutch will kill synchros.
+1IMBoring25 wrote:If I want to go immediately after stopping, I've been known to DCHT into first while slowing for the stop sign. Any other case, and I just wait until going less than walking speed before starting to push the shifter into the gate. Applying pressure into the first-gear gate at road speed without a double-clutch will kill synchros.
