Flat Black!
Re: Flat Black!
Spray it with this:
Re: Flat Black!
I got some plastidip black spray and started touching up my truck.
Cover peeled paint areas on hood:
Imitation hub covers:
Re: Flat Black!
Time to do the rest, like you planned!!
I gotta get me a couple cans of this stuff and make my wheels black.
Re: Flat Black!
InlinePaul wrote: Cover peeled paint areas on hood:
You should sand those chipping/peeling areas down smooth and then cover it with the PD. Actually, do the entire panel or better yet, the entire vehicle.
Re: Flat Black!
That would be the right way to do it. Suppose it's a good opportunity to see how the stuff peels.Shadow wrote: You should sand those chipping/peeling areas down smooth and then cover it with the PD. Actually, do the entire panel or better yet, the entire vehicle.
Re: Flat Black!
InlinePaul wrote:That would be the right way to do it. Suppose it's a good opportunity to see how the stuff peels.Shadow wrote: You should sand those chipping/peeling areas down smooth and then cover it with the PD. Actually, do the entire panel or better yet, the entire vehicle.
Suggestion for you--- watch a few YouTube videos to learn how to apply and how to remove the stuff. A simple thin coat will not allow you to peel it correctly. You need several (usually 3 or 4) coats if you plan on removing the stuff. The best videos to learn about PD are from a guy named Fonzie at dipyourcar.com.
http://www.youtube.com/user/DipYourCarcom
Re: Flat Black!
You are right. This stuff is not fool proof. I got some overspray on my windshield and it will require a razor blade to remove it, but it doesn't bother me and with two stone chips I am just waiting for the crack so I can replace the windshield anyway. But the truck is kind of a beater, pretty rusty underneath, right door bottom rotted to separation, tailgate and bed side have holed through. I need someone who can dedicate the time to do it right. Would love to get this stuff in a darker green and paint whole truck, or maybe red to match Clutchdisk's truck.Shadow wrote: Suggestion for you--- watch a few YouTube videos to learn how to apply and how to remove the stuff. A simple thin coat will not allow you to peel it correctly. You need several (usually 3 or 4) coats if you plan on removing the stuff. The best videos to learn about PD are from a guy named Fonzie at dipyourcar.com.
I'll watch the video later. Thanks!
Re: Flat Black!
Re: Flat Black!
This is probably going on my mom's rocker panels. She complained recently that they get covered in road grime that she can't remove.
Re: Flat Black!
That's classier than my seasonal plastidip bra.
Re: Flat Black!
Toe of my black shoe was all scuffed up, so I taped it off and sprayed it with PlastiDip. Looks much better than it did, may need a second coat:
Re: Flat Black!
I use a Sharpie for small blemishes in my shoe. If you look closely you can see it, but from head height you need decent vision (which most people around here don't have) and either way you need to be staring at my feet.
Re: Flat Black!
Thought about a Sharpie, but the Plastidip seemed like a more fun way to do it. It is extra work masking off the area. But it smells better than the Sharpie and the smell lasts longer.
There is a lady who is plastidipping all sorts of things for decorative purposes, including the toes of some silver sparkling shoes as shown on her web site: http://www.tatecreates.com/plasti-dip/
