Downhill in gear
Downhill in gear
Does going downhill in gear, such as 3rd (of 5 gears) on a moderate decline - use any fuel? I thought not, since as long as the accelerator isn't depressed. I've been doing that over the years assuming it would preserve the brakes just a bit. I've read in other forums it's not advisable, causing wear on other components, with the theory brakes are typically less expensive to replace than transmission components. Still, I'd think any stress on the drivetrain or fuel usage (if any) while coasting downhill in gear would be minimal?
Re: Downhill in gear
With respect to the first question, it depends. Many newer cars can completely shut off the injectors in a mode commonly called DFCO (Deceleration Fuel Cut-Off), but older injected vehicles and especially carbureted ones will probably keep some small amount of fuel flowing. That amount of fuel is unlikely to materially be affected by the gear selected unless you have to use throttle to maintain the desired speed, however.
With respect to the second, there really is minimal wear, especially if you double-clutch the downshift. The only exception would be if you force the shifter into a gear completely inappropriate for the speed you're traveling and mechanically overrev the engine or drivetrain.
It can actually be dangerous to descend long, steep grades without downshifting. While being used, brakes and brake fluid heat up. This causes them to become less effective (brake fade) and if used for a long time without being allowed to cool can even lead to complete failure.
Then it sounds like I should be doing what I've always done. Use common sense and what 'feels' right. A few years ago I lost the brakes on an older Honda Accord I had, a leak in the lines. Was very fortunate that I wasn't too far from home, but more fortunate that it was a standard shift where I could slow down enough to be safe.
Yep, in gear on down hills if there are much of a hills. In the Rocky Mountains and other mountains you really have to keep it in gear.
